Intake Manifold
Old Sep 4, 2007 | 07:46 PM
ss150's Avatar
ss150
Intake Manifold
I was wondering what my options are as far as carbureted intake manifolds go for my 302? I wasn't sure since it's a truck that other non-truck 302 manifolds would work on it. I have also heard of people using mustang manifolds, so I wasn't sure. My dad has a manifold from his '72 Mustang 302. Would this work?
Old Sep 4, 2007 | 09:11 PM
eco's Avatar
eco
I can't say I have any first hand experience with this, but a summit racing catalog should be able to tell you if they interchange or not.
Old Sep 4, 2007 | 09:23 PM
ss150's Avatar
ss150
Well I've went to jegs.com and 302 manifolds are limited in the truck section, but there is a lot under the mustang 302's. I thought they would not interchange, but now that I think of it, I thought I heard of someone using a mustang manifold on their truck. Just wanting to see if any know's FOR SURE from experience.
I'm beginning to think they are seperated because manifolds are designed to meet the power band and needs of a truck...? They may still fit.
Old Sep 4, 2007 | 09:42 PM
302 F-150's Avatar
302 F-150
Any 302 intake will work fine. When I did my swap I used an edelbrock performer manifold and I am pretty happy with it. The mustang manifold will work too. Summit also makes their own manifolds that are slightly cheaper than other brands that you may want to consider.
Old Sep 4, 2007 | 09:43 PM
Scndsin's Avatar
Scndsin
It'll be a 2 barrel, cast iron & heavy as hell. The carb that comes on it will have bigger venturis than the secondaries of a small holley & will suck gas like no tommorow. Any non-boss 302 intake will work. If you must go carb, find a cheap aluminum dual plane (Professional Products, Weiand) & pair it with a small 425-500 cfm Holley.
Old Sep 5, 2007 | 06:23 AM
ss150's Avatar
ss150
Actually, I wasn't referring to a stocker, my dad's intake manifold is made by B&M and allows for a blower to sit nice and "purdy" on top! If it fit my dad's '72 non boss 302, it will fit the 302 in my truck?
Old Sep 5, 2007 | 06:40 AM
Scndsin's Avatar
Scndsin
Yes, it'll fit...
Then you'll only have several other issues to over come to make the whole shootin' match work. To be perfectly honest I figured someone whould have jumped in to dissuade you from this course of action before now.
A blower manifold? Does it come with the blower?
I know they make block off plates for tunnel rams, But an adaptor plate for a blower manifold kinda defeats the purpose. It'll have short runners & no low end torque.
Old Sep 5, 2007 | 01:57 PM
ss150's Avatar
ss150
double post
Old Sep 5, 2007 | 02:02 PM
ss150's Avatar
ss150
Lol, yes, it will have a blower on top of it. Since that fits, there is one less thing I need for my carb swap!
I have forgotten though, what is the limit of the stock internals on my '92 302? I'm trying to decide how much boost I will run.
Old Sep 5, 2007 | 04:14 PM
eco's Avatar
eco
Summit's catalog says it will work.
http://store.summitracing.com/partdetail.asp?part=EDL%2D2121&view=32&N=700+150+4 294907843&appfilter=1#Application
The carb manifolds will work from 1968 to 2001 (did they even make them up to 2001??) for the 302.
Old Sep 5, 2007 | 09:26 PM
ss150's Avatar
ss150
Ok, thanks eco. Yeah, havn't heard of any production of a carbed 302 in any Ford vehicle in 2001.
Old Sep 6, 2007 | 12:00 AM
eco's Avatar
eco
Did they make ANY 302 in 2001???
Old Sep 6, 2007 | 12:50 PM
ss150's Avatar
ss150
Good point. All I know of is 281's and 331's.
I have forgotten though, what is the limit of the stock internals on my '92 302? I'm trying to decide how much boost I will run until I get a new rotating assembly.
Old Sep 6, 2007 | 01:06 PM
fast83's Avatar
fast83
well I know the mountainers are 302 up to 2000 yeah I was shocked too but accurate
Old Sep 6, 2007 | 01:09 PM
fast83's Avatar
fast83
dude only run 6 to 8 pounds with stock internals your head gaskets will fail. I am all for a carb motor but it will be a pain in the azz to covert it to carb I would just to NOS on the EFI 302 you have now cheaper and easier and still keep the efficancy of the EFI
