2000 Wiper Problem
Old Sep 4, 2007 | 12:02 PM
JKTX21's Avatar
JKTX21
2000 Wiper Problem
Hello All. Unfortunately / fortunately this is my first post on this forum.
I have a 2000 Expedition and the front wipers worked great until recently. The first symptom, before they quit working all together, was they wouldn't work on intermittent, just low & high speeds. Then would run on a bit after I turned the switch off. And then the wipers stopped working all together.
I have gotten into it some.
1) Fuses check out ok, and I can hear the switch powering the relay under the hood.
2) I powered the motor manually (with the timer cover off) and the motor worked fine.
3) Checked the harness & it looks like it has power 100% of the time.
4) Thinking the problem was the harness on the motor cover, I hooked up a new motor and that is not the problem. Still not working.
So my only conclusion is that there is a bad ground in the system, the harness is bad, or there is another component I am not aware of. Any help? Thanks in advance.
***Also, the rear wiper motor treated me the same way before it stopped working about a year ago. Never looked into what may be wrong there.
Old Sep 4, 2007 | 01:39 PM
dakota_viking's Avatar
dakota_viking
This sounds like the dreaded ghostly Multi Function Switch (blinker/dimmer/wiper switch) on the steering column.
Since you have tested the components seperately, the switch is most likely the problem.
It's not that tough of a replacement, just time and patience.
Good Luck,
Tim
Old Sep 4, 2007 | 02:21 PM
gherrick's Avatar
gherrick
On my 2000 XLT the rear wiper had quit working and front would inch along, barely moving.. Put in new wiper motor in front, w/same results. Took to Ford dealer and they said a ground was bad. The had to do some wire splices in the wire loom that runs alongside the fusebox under the hood. Cost $60 but well worth getting rid of my headache! Wipers front and rear work great, this ground also effected my cruise control. I do not know which ground or circuit it was as they had it all taped up when I picked it up.
Old Sep 4, 2007 | 03:00 PM
crp2000eb5.4's Avatar
crp2000eb5.4
I think there is a recall on the front wiper moter problem. Check the Recall/TSBs at the top of this page for 2000 Expeditions.... Maybe it fits your problem.
Old Sep 4, 2007 | 03:02 PM
crp2000eb5.4
Here is the summary.....
Defect Summary:
VEHICLE DESCRIPTION: PASSENGER CARS, SPORT UTILITY VEHICLES, AND LIGHT AND MEDIUM DUTY PICKUP TRUCKS. A SWITCH LOCATED IN THE PLASTIC COVER OF THE WIPER MOTOR GEAR CASE COULD MALFUNCTION AND OVERHEAT, POTENTIALLY RESULTING IN LOSS OF INTERMITTENT WIPER FUNCTION, LOSS OF WIPER PARK FUNCTION, COMPLETE LOSS OF WIPER FUNCTION, OR IGNITION OF THE PLASTIC COVER MATERIAL. SWITCH MALFUNCTION IS MOST LIKELY TO OCCUR WHEN THE INTERMITTENT SETTING OF THE WIPERS IS BEING USED, OR WHEN SNOW OR ICE OBSTRUCTS THE BLADES FROM RETURNING TO THE "PARKED" POSITION AT THE BOTTOM OF THE WINDSHIELD. THESE VEHICLES WERE BUILT AT THE FOLLOWING ASSEMBLY PLANTS: ATLANTA PLANT FROM 2/11/00 THROUGH 7/31/00; CHICAGO PLANT FROM 2/14/00 THROUGH 8/4/00; KANSAS CITY PLANT FROM 2/26/00 TO 9/4/00; KENTUCKY TRUCK PLANT FROM 2/18/00 TO 8/31/00; MICHIGAN TRUCK PLANT FROM 2/23/00 THROUGH 8/3/00; NORFOLK PLANT FROM 2/21/00 THROUGH 7/27/00; WAYNE STAMPING AND ASSEMBLY PLANT FROM 2/25/00 THROUGH 8/15/00; AND WIXOM PLANT FROM 2/15/00 THROUGH 8/8/00.
Old Sep 4, 2007 | 03:12 PM
JKTX21's Avatar
JKTX21
Well, after hanging out with my Ford today found out a few things, but my wipers still don't work.
I pulled up the rear wiper arm and the motor works, but it doesn't know where it's at, so it binds when it parks and won't work properly unless I pull it up. Don't really care if it doesn't work.
I had a good idea the switch in my column was still good (as I could hear the relay clicking) but I went ahead and put a new one in. Same problem, front wipers don't work. (I have a brand new multi-switch for sale if anyone is in need)
So the only logical conclusion I can draw is that there is a bad ground between the relay and the wiper motor. I don't really know where to look for this, so I guess it's going in the shop
Old Sep 8, 2007 | 06:24 PM
JKTX21's Avatar
JKTX21
Turns out SOMEONE removed a relay from the GEM (there are two). I'm guessing the boneheads that fooled with my air suspension. Works fine now!
hunter101
May 13, 2022 12:55 AM
breeze4820
19
Feb 14, 2017 03:15 PM
vasten
1997 - 2003 F150
15
Mar 26, 2008 09:20 PM
sasquatch999
Oil & Lubrication
Oct 23, 2007 08:37 AM
Clem B.
Offroad & 4x4
Jan 29, 2007 03:00 PM
