410 CI Engine
Old Dec 2, 2002 | 02:01 PM
William's Avatar
William
410 CI Engine
Next project will be a 4.05 or 4.08 bore, 390 rods and a 428 crank. Plan on using 72cc heads. I think the crank is available at reasonable cost, rods are available, pistons seem to be the issue. I have heard of custom pistons to adjust the compression ratio to 9.0 to 1. I have heard of machining pistons to get deck clearence and cr. What have you Guys been using? This will be a truck engine, low RPM and lots of torque. Lets do a little bench racing and see what we can come up with for say a budget of 3000.00 for the long block.
William in Atlanta
Old Dec 2, 2002 | 03:01 PM
1 Big Mike's Avatar
1 Big Mike
410 CI Engine
Ross Racing makes forged pistons for the 410 and they can be dealt with through Summit and they have a website but don't know what it is. I have heard that shaved 390 pistons will work also and I know that somebody still makes the original cast pistons as well but I wouldnt use those if I were you. I think for pistons Ross Racing would be your best bet.
Old Dec 2, 2002 | 06:59 PM
FE427TP's Avatar
FE427TP
410 CI Engine
I believe Flatlander racing has Ross pistons in stock for $569
Old Dec 4, 2002 | 10:46 AM
BB's Avatar
BB
410 CI Engine
Old Dec 4, 2002 | 06:50 PM
Scotty1's Avatar
Scotty1
410 CI Engine
There is a site that I found that has a lower price than Flatlander. I can't remember the name of the site. I however would use flatlander simply becuase they ahve been around a while and are a trusted company. Thats my opinion.
Scotty
Old Dec 5, 2002 | 10:29 AM
William's Avatar
William
410 CI Engine
Just for grins I checked the price on a 428 crankshaft at one of the local parts suppliers! $350.00 bucks, and I'm thinking "hey that ain't bad", then the guy asks if I have a core! Nope! Ooh, now the price is $550.00. So, $700.00 for the pistons, $550.00 for the crank, say $800.00 for boring, honing, gaskets, rings, bearings, $1200.00 for a set of Ebock heads, another $500 for a Ebock carburetor and intake, $350.00 for adjustable rockers and new pushrods, say another $300.00 for miscellaneous stuff like plugs, wires, anti-freeze and so on we're at about $4400.00. Well maybe next year!
William in Atlanta
Old Dec 5, 2002 | 11:17 AM
stephenw's Avatar
stephenw
410 CI Engine
Yes, mine has turned out to be anything BUT a budget re-build too!! When I bought the 410 for $550(fan to NP435), I was told that it had miles on it but was still good enough to drop in and drive. There's one born every minute, and my turn was up I guess. As soon as I pulled the pan to look at the bearings (thankfully before an install, but after travelling 750 miles, and already paying for it) I knew I was in big trouble. BTW, you forgot to budget for align honing, balancing, new flywheel (~$350), clutch kit, special gaskets recommended by Edelbrock for their heads and intake, and on-and-on.
One last thought: don't get caught with your guard down when you figure out what compression ratio you want/can use. I originally built mine to 9.9:1, and that proved just not do-able for my truck, the way I use it heavily loaded most of the time. This in spite of my own high aspirations and attention to detail, and assurances from various web-persons that it would be ok. My machinist tried to talk me down from the outset, but I argued with him and did it my way. Now I'm torn apart and still waiting for the Ross dishes that I should have used the first time.
But WOW, the extra torque from the 3.98 stroke crank is awesome, so don't give up on the idea!
Good Luck, Steve
Old Dec 5, 2002 | 01:52 PM
karlsd's Avatar
karlsd
410 CI Engine
Wow! Is a 428 flywheel really that much money? My truck is an auto, so I needed a 428 flexplate when I dropped in the 428 crank, but I found that they were readily available for about $50.
I think that 9.5:1 is about the limit for compression on an iron-headed, pump gas FE in a truck, and even that may be pushing it depending on a host of other factors (thermostat temp, cooling system condition, ignition timing, cam duration and timing, even the climate where you live). You might get away with 9.9 or 10:1 with aluminum heads, but that is $1200 I don't want to spend.
Old Dec 5, 2002 | 02:30 PM
Ratsmoker's Avatar
Ratsmoker
410 CI Engine
You can also take the TRW L2291 pistons and cut them down to zero deck.
Old Dec 5, 2002 | 04:37 PM
1 Big Mike's Avatar
1 Big Mike
410 CI Engine
Not to brag but I got my 428 crank for free. Lucky me
William
Dec 2, 2002 04:38 PM
William
Oct 28, 2002 08:18 PM
fsmartin
Jul 20, 2002 09:56 PM
William
Apr 5, 2000 02:00 PM
