flywheel
Old Dec 5, 2002 | 12:23 PM
big_red_79's Avatar
big_red_79
flywheel
i bought a flywheel off of ebay, and the guy said it was for a 390, so far it fit good, untill i decided to put the presure plate on, the threaded holes wont line up, what could cause this,
any help is appreciated,
thanks much
NATE
Old Dec 5, 2002 | 05:36 PM
lee's Avatar
lee
flywheel
Nate,
I ran into the same problem with a new flywheel I bought at the local parts house. Only 2 holes lined up. At first I was mad as he|| then for some reason I rotated the flywheel one bolt hole and tried it again. Each time I rotated it seemed that 2 different holes would line up each time I rotated one hole. I kept rotating and low and behold they all finally lined up on about the 4th rotate.
Hope this makes sence,
Lee
Old Dec 5, 2002 | 05:41 PM
big_red_79's Avatar
big_red_79
flywheel
so are you saying i gota unbolt the flywheel, and turn it one bolt hole or so, or did you turn the presure plate till the holes lined up?
thanks
Nate
Old Dec 5, 2002 | 08:32 PM
lee's Avatar
lee
flywheel
Nate,
I'm sorry. I re-read your post. I at first thought you had a flywheel to crank shaft bolt up problem. Now I see that you have a pressure plate to flywheel bolt up problem. I had both when I rebuilt my engine. To get the flywheel to bolt up to the crank I had to do as I stated in my last post. Then I could not get the pressure plate to bolt up. This was because the parts house gave me a clutch kit for a 400M not a 390.
Again, disregard my last post. I misunderstood your problem. Sorry.
Lee
Old Dec 6, 2002 | 07:08 AM
big_red_79's Avatar
big_red_79
flywheel
i'll have to try another parts store, and see what happens,
thanks for the info
Nate
Old Dec 6, 2002 | 08:46 AM
richlars_7's Avatar
richlars_7
flywheel
samuelalynch
Jun 17, 2011 01:43 PM
fordmudrunner2020
Apr 26, 2005 10:47 PM
foggy_2
Apr 25, 2002 02:42 AM
