spark plug problems
Old Sep 3, 2007 | 05:29 PM
whitetail hitman's Avatar
whitetail hitman
spark plug problems
hey yall
i just installed new plugs, wires, distrubiter cap and button, on my 1990 f-150 they exact way it was, and now its not wanting to start.
its an EFI 302 5.0
any suggestions?
Old Sep 3, 2007 | 05:45 PM
quicklook2's Avatar
quicklook2
does it turn over? spark? fuel?
give more details.
did you leave out the rotor?
Old Sep 3, 2007 | 05:58 PM
whitetail hitman
it turns over, sparks, but its almost like its missing a few cylenders. should i take the cap wire off and try to start it over at TDC?
Old Sep 3, 2007 | 06:03 PM
quicklook2's Avatar
quicklook2
try starting fluid.
double check firing order.
check inertia switch.
Old Sep 3, 2007 | 07:34 PM
fmr9's Avatar
fmr9
I did this once many years ago on a 289 cu inch, and had the same problem. Turns out I had them in the right order, I just started one hole off.
Was so embarrassing.
Good Luck Frank
Old Sep 3, 2007 | 07:45 PM
whiteyfordzx5's Avatar
whiteyfordzx5
+1 on re-checking the firing order
Mike
Old Sep 3, 2007 | 07:50 PM
89frankenford's Avatar
89frankenford
Lightbulb
yeah definately recheck the firing order and make sure the plugs wires are in snug.
Old Sep 4, 2007 | 12:45 PM
whitetail hitman
ok im about to recheck the firing order, if that dont work ill try some more process of elimination.
Old Sep 4, 2007 | 12:51 PM
LoosMaster's Avatar
LoosMaster
Also make sure you're going in the right direction. If I remember, the wires run CounterClockwise when looking at the top of the distributor and the #1 terminal is at or near the cap clip on the R/H side looking from the front of the vehicle.
Old Sep 4, 2007 | 01:42 PM
whitetail hitman
frustration
Good Luck Frank
i started with #1 on the marked #1 on the position marked #1 on the distrubitor cap, and worked all the way around the cap counter clockwise in firing order, still nothing.
it cranks fine it just wont start
it feels like all the wires are crossed but they arent.
also when i got my engine rebuilt, my cam was installed 180 out. maybe that has something to do with it?
Old Sep 4, 2007 | 03:04 PM
quicklook2's Avatar
quicklook2
you never said if you tried starting fluid.
Old Sep 4, 2007 | 11:56 PM
whitetail hitman
its efi.
i figured out the problem but its still running rough, i just had the trans. rebuilt a few months ago and havent had any problems, maybe its something to do with the air check valve.
im thinkin towards an exorcism
Old Sep 5, 2007 | 08:20 AM
EPNCSU2006's Avatar
EPNCSU2006
1-5-4-2-6-3-7-8 right?
4 8
3 7
2 6
1 5
Front of engine
I'm sure you have it right, but it can't hurt to triple check...
Also have a look around and make sure nothing got unplugged accidentally or forgot to plug back in when you were finished. Since it just started when you changed plugs/wires/cap/rotor, it is most likely something to do with replacing those things.
Old Sep 6, 2007 | 04:17 PM
whitetail hitman
i gave up on trying to fix it myself and decided to take it to a shop around here. it turns out i have a bad injector. ill know something my tomorrow.
Old Nov 26, 2009 | 02:57 PM
rocketwrenchbender's Avatar
rocketwrenchbender
I have a major problem and hope some one can help. I have a 1989 F-250 the plugs must be original as two have rusted to the point were the plugs have broken leaving the grounding electrode stuck in block. I have used an ez out, deep creep heat, cussing and screaming any other ideas outside of the removal of heads
