Sponsored by: Real Truck
Remote Starter - glow plug?
Old Sep 3, 2007 | 10:03 AM
Beach_Bob's Avatar
Beach_Bob
I just had a remoter alarm/starter installed in my 05 250 and I'm wondering if the Ford has a glow plug wire that the installer should have tapped into instead of just setting a delay timer. I'm a bit upset at the overall install and this item would probably set me over the edge....
Old Sep 3, 2007 | 11:18 AM
JOE-M's Avatar
JOE-M
On the '02s there isn't a seperate glow plug wire to tap. It all runs through the PCM. I don't know for sure on your truck, but I'll bet it's the same. I installed my alarm and set it up on a 10 second delay for the glow plugs (year round).
Joe
Old Sep 3, 2007 | 11:37 AM
aldridgec's Avatar
aldridgec
Yeah, that is the problem with the newer trucks. There is probably a way to tap directly into the cluster and through a relay, but delay is the only way to go for the most part. You could tap into the GPR, but since that is on for a couple of minutes sometimes your truck would never start!
I wasn't happy about it either, having the 15 second delay when the truck is already warm. I've gotten used to it, not a big deal anymore.
Old Sep 3, 2007 | 12:17 PM
Beach_Bob's Avatar
Beach_Bob
The delay on warm days is a bit annoying, but I'm actually more concerned in the dead of winter that the delay may not be enough. We get some mighty (-40) cold nights at times...
Old Sep 3, 2007 | 12:33 PM
JOE-M's Avatar
JOE-M
On mine you can set it for different times. 10, 20 or 30 if i remember right. Check your alarm owners manual and it should tell you how. What brand did you buy? Maybe someone can tell you how.
Joe
Old Sep 3, 2007 | 04:14 PM
UP_There's Avatar
UP_There
my alarm is wired directly to the glow plug relay, waits til the light goes off to startup. But this is on a 2000 F250.
Old Sep 3, 2007 | 04:47 PM
wlihntr's Avatar
wlihntr
are you sure about that? because the WTS light is controlled by the PCM not the GPR
Old Sep 3, 2007 | 06:02 PM
cparks's Avatar
cparks
remote start
I have installed two of these, one on my 01 7.3 and now on my 05 6.0 and used the Ford boxes with remote start and door locks. They both use the timer which I recall is set at 15 seconds. They work great. As far as the winter, I always plug my truck in if it is below 0 and it starts great.
Old Sep 3, 2007 | 06:27 PM
Green_Dually's Avatar
Green_Dually
If its set for 10 secs,it border line for the light during the winter.Mine was set like that also,i had my doubts that it would be long enough,but it was.Just real close.
I now have mine set to 20 secs,gives the plugs a little more time to warm up.
Old Sep 4, 2007 | 09:04 AM
jomac11's Avatar
jomac11
I put an aftermarket remote start/alarm on my buddies 01 F250, and wired it in to the wait to start wire. It is a pretty straightforward process, and as soon as the light goes off, the truck starts to crank. Almost every major manufacturer of remote starts has a wire to connect to your wait to start on a diesel.
Old Sep 4, 2007 | 09:31 AM
Beach_Bob's Avatar
Beach_Bob
I'm not concerned with the remote system's capabilities (Compustar), but whether the installers screwed up this install. To my mind, hooking into the glow plug ready wire makes more sense than running off of a timer. The installers put it on a timer, so I just wanted to know whether they were incompetent or if the 05 diesels were too much of a pain to expect them to do it that way
Old Sep 4, 2007 | 10:27 AM
wlihntr's Avatar
wlihntr
that would not be the way to do it. the GPR can keep the glow plugs energized for up to two minutes after the WTS light goes off. the way to it, if you did not want the timer is to tap into the WTS light cuircut as jomac11 said
Old Sep 4, 2007 | 10:32 AM
jomac11's Avatar
jomac11
It is not hard at all to hook into the wait to start wire, the only thing they have to do is snip the wire, and put in a diode so that the alarm doesnt backfeed into your gauge cluster and short it out. It is probably faster to hook it up that way then it is to setup a timer.
Old Sep 4, 2007 | 10:54 AM
aldridgec's Avatar
aldridgec
I'm gonna have to check a couple of wiring diagrams, but the problem here is that there is not a wait to start wire. I know for a fact anything newer than 02 doesn't have one, b/c i looked into this with my R/S and a friends 07 R/S. It is controlled by a data line from the PCM, and the cluster internally lights the indicator.
Old Sep 4, 2007 | 12:42 PM
jomac11's Avatar
jomac11
I'll have to look into that I guess. I have my password at home for DEI's directwire online database, so I'll take a look and see what it has to say.
Y2KW57
59
Jan 29, 2017 01:44 PM
mattdoc88
Mar 31, 2014 08:20 PM
bubba_v2008
Apr 11, 2011 08:26 PM
AndeyHall
Nov 22, 2010 09:14 PM
yellow73bb
Jan 7, 2005 12:42 AM
