351C/400 difference
Old Oct 21, 2007 | 01:48 PM
Colo79Ford's Avatar
Colo79Ford
Easiest way is to look at where the thermostat housing bolts up. The 351c will bolt up flush with the top of the block ( distributor and t-stat housing on same level). On the 400/351m the block rises about an inch and the thermostat housing bolts to the raised piece of the block (Thermostat bolts on on a raised lip, about an inch above where the distributor base rests.).
oddfordjunkie
Jan 13, 2013 11:43 PM
77 puller
Aug 10, 2007 12:29 AM
cruz76
Mar 26, 2006 05:40 PM
cruz76
Mar 24, 2006 09:14 PM
675hp351c
Nov 21, 2003 09:25 PM
