c 4 on a 400
Old Nov 10, 2003 | 08:36 PM
675hp351c's Avatar
675hp351c
Question c 4 on a 400
Hey guys I am thinking of builing a 400 in place of my clevelnd will the c-4 bolt to the 400 ?
Old Nov 10, 2003 | 08:37 PM
675hp351c's Avatar
675hp351c
sorry for the speeling should look at it first
Old Nov 10, 2003 | 09:55 PM
ecarter50's Avatar
ecarter50
351c and 400 have different bellhousing bolt patterns, except a few 400 have 302/351w/351c pattern. There is a c4 bellhousing available with 351m/400/460 bolt pattern.
Old Nov 11, 2003 | 04:07 AM
675hp351c's Avatar
675hp351c
thanks for the info i will check and try to find one
Old Nov 11, 2003 | 07:42 PM
ecarter50's Avatar
ecarter50
400/460 C4 bellhousing on Ebay.
Old Nov 20, 2003 | 09:55 PM
tdup's Avatar
tdup
Why would you want to use a c4? If you drive it very hard with a 400 it wont take.
Old Nov 21, 2003 | 05:01 PM
675hp351c's Avatar
675hp351c
i have been runnig one that is pro built on a cleveland that pushs in at 573 on motor plus n02 i think it will do just fine
Old Nov 21, 2003 | 06:24 PM
Ecuri's Avatar
Ecuri
No offence, but I gotta agree with tdup, the C4 may be fine, but in this case, bigger is better, and there are a lot more C6s than C4s available, IMO, for this engine... should be easier to find and cheaper to buy.
Old Nov 21, 2003 | 08:50 PM
675hp351c's Avatar
675hp351c
I know but to each his own
Old Nov 21, 2003 | 08:52 PM
tdup's Avatar
tdup
c4 vs c6
There is no doubt that a very well built and modified c-4 can handle a lot. But if it does give it up get a PRO-Built c-6. A well built c-6 can move monster trucks. I have never seen a c-4 in one.
Old Nov 21, 2003 | 09:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
The 400 is a low rpm torque motor, the 351C is a high rpm HP motor. This subjects the transmission to different types of stress. Use a C6 behind a 400. If you have a built 400 make sure you have a built C6 also. Match the components...
johnson2007
Nov 15, 2010 05:17 PM
YoungMT Hick
15
Oct 21, 2007 01:48 PM
cruz76
Mar 26, 2006 05:40 PM
mositso
21
Oct 6, 2003 03:47 AM
TC73Fleetside400C4
Sep 6, 2001 05:17 PM
