Klunking when loaded
Old Sep 5, 2007 | 07:57 PM
F350-6's Avatar
F350-6
Sorry, I meant did you check the sway bar bushings? Don't overlook simple things like a loose spare tire, or tools in a toolbox bouncing around.
Does your clunk come bouncing up or down? Is it related to any sway left or right?
Old Sep 5, 2007 | 10:32 PM
MONTANA350's Avatar
MONTANA350
Originally Posted by Ridgerunner500
While I was under there I looked at all leaf springs and had a die bar which
I used to pry at all things related to suspension and everything seemed tight.
Just went out and jumped up and down on bumper and everthing was quiet.
Nothing is close to sway bars. I'm leaning toward those shocks. Randy
The cracks in my leafs were hair-line and very hard to see, until all of the weight was off of the rear end. Then, the pieces would just slide right out. My wife slapped me when she remembered the narrow mountain road that we were on the day before!!
Old Sep 6, 2007 | 02:16 PM
Ridgerunner500's Avatar
Ridgerunner500
The klunking is when it's loaded and I hit just a large Crack in the road not
a huge bump, but it sounds more like I ran over a 2X4 or something. I
didn't notice any sway noise or problems left or right. Just checked the
sway bar bushings and there seems to be a slight amount of clearance
around bar. How tight should they be? Thanks Randy
Old Sep 6, 2007 | 02:18 PM
Ridgerunner500
Did you have it jacked up to get all the weight off the rear axle? Randy
Old Sep 7, 2007 | 10:44 PM
MONTANA350's Avatar
MONTANA350
Yes, It was on a lift at the brake shop. Once it was up, the pieces almost fell out.
Scott
sseebart
Jun 24, 2014 04:17 PM
2thirteen
6.7L Power Stroke Diesel
Feb 12, 2012 07:59 PM
cnelso48
Nov 23, 2010 10:41 PM
germchef
Jan 23, 2007 08:41 PM
Sharpshooter77
Dec 23, 2006 05:02 PM
