help
Old Sep 1, 2007 | 03:38 PM
eviltrekker's Avatar
eviltrekker
help
i cannot get the 10mm bolt to break loose for cps sensor. i think it might be original 1.tried everything that was mentioned,just short of taking radiator out which i am considering. tried spraying it,does any one have any other ideas,tried spraying it,tapping it,
Old Sep 1, 2007 | 04:29 PM
c00nhunterjoe's Avatar
c00nhunterjoe
use a deep 10mm 6 point socket, a 3 inch extension and a long handled 3\8 wratchet. i havent had one yet that wouldnt come out using that combo, it puts you just outside of the belt and the handle is away from the fan blades. if the bolt is rounded then get a twist off socket, it will come out guranteed.
Old Sep 2, 2007 | 09:32 AM
bodabdan's Avatar
bodabdan
Veteran: Navy
Not to sound like too much of a smart a** but righty-tighty lefty-loosey does apply. If you have that part correct then it's just a matter of brute force. Someone may have used a thread locker or you could have some damaged/corroded threads. If you do get it to break loose and it feels funny, then flood it with a good penetrating oil and turn it back and forth to help the oil work it's way in there. If you dont have a ratchet that is long enough to do what coonhunterjoe described then put a cheater pipe on the longest one that you do have. Twist it like you hate it.
JimG1098
35
Jan 23, 2015 03:29 PM
FLRob
Feb 12, 2014 11:37 PM
JEB70
Jan 22, 2011 06:21 AM
Greywolf
Garage & Workshop
32
Aug 13, 2010 01:35 PM
V10man
Aug 28, 2002 06:46 PM
