Sponsored by: Real Truck
creaking driver's door window
Old Aug 7, 2002 | 07:55 PM
V10man's Avatar
V10man
My driver's door window is creaking like crazy and it's making me crazy! I tried spraying the window track and door weather strips with silicone spray but it didn't help. If I press hard against the glass or put the window down a bit it stops. Any ideas?
Old Aug 7, 2002 | 09:29 PM
charlesvalentine's Avatar
charlesvalentine
Can you tell if the creaking is coming from the top or bottom of the door? if its the glass edge rubbing on something you can test this by puttin a thin strip of cloth all around where the door glass touches the window frame. If the creaking goes away thats it. If its lower, the tracks may be loose or something rubbing inside.
Is this only happening at speed?
99 F250SD EC 5.4L 3.73 285 BFG/ATs...
99 Expy EB 5.4L
Old Aug 28, 2002 | 06:24 PM
V10man's Avatar
V10man
I think I got it fixed! I took the door panel off and removed the inner weather strip along the bottom(top of the door panel) I liberally coated the strip with silicon spray. The felt strip, the insides(where it clamps over the door) and the top where the door panel rides on it. So far, so good! No more creaking.
Old Aug 28, 2002 | 06:46 PM
thewhiteford's Avatar
thewhiteford
trojantiger
2004 - 2008 F150
Apr 24, 2010 04:38 PM
jimi
Jan 11, 2008 05:34 AM
gui88ford
2004 - 2008 F150
Nov 30, 2007 12:26 PM
RUBICON
Apr 18, 2007 07:42 AM
brianas
Dec 11, 2003 09:09 PM
