1997 4.0 spark plug wire routing
Old Sep 1, 2007 | 01:50 PM
97Ranger4.0's Avatar
97Ranger4.0
I recently purchased a 1997 Ranger with the 4.0 and am in the process of replacing the spark plugs and wires. I have the factory service manual (covers ranger and aerostar) which has a diagram for routing the plug wires. However the wires currently on the driver side (4,6 & 5) pass under the middle of the intake manifold (between the 2 & 3 in the top picture) rather than around the outside of the engine and clips 1,11 & 9 are missing. I tried routing the new wires around the engine like in the picture but the #2 wire is too short (bosch part# 09785) even though, it is supposed to be the correct wire set for this application. Can anyone comment on which way the wires are actually supposed to be routed? The wires I removed are grey, individually numbered and have "B7028 4F6 HF" labeled on them, anyone know if these are OEM? Also, after reviewing the paperwork that came with the truck I discovered the intake manifold gasket was changed so it is possible the shop rerouted the wires at that time. Thanks.
Old Sep 1, 2007 | 08:10 PM
Rockledge's Avatar
Rockledge
That's one of the problems with not using OEM replacement (Motorcraft) wires. Some aftermarket wiresets may be as good quality-wise, but you often end up with with a few that are either too long or too short.
Sounds like the wires you are replacing are the originals (or Motorcrafts).
Jose A.
Aerostar
19
Apr 16, 2014 06:37 PM
dwollum
1983 - 2012 Ranger & B-Series
Apr 13, 2014 12:46 PM
JaySVX
Jul 14, 2013 03:37 PM
waterbear
Aerostar
Sep 6, 2012 03:01 PM
LARIAT 85
Feb 10, 2011 09:51 AM
