'99 F350 heater hoses??
My '99 F350 (with 7.3 PSD) has these strange looking quick disconect fittings on the heater core ends.
I understand that there is a special tool made to remove these hoses.
I have a picture of the tool and instructions on how to use it.
I really don't want to spend $30-$50 for the tool just to use it one time, as my new GATES hoses DO NOT have these fittings.
In looking at the diagram it looks like I could possibly put a common hose clamp around the locking tabs on these fittings to act like the special tool would and then just slip the hose off--anyone have any experiance with this?? also:Why would Ford use such a thing?? to aid with assembly time at the factory?? Thanks!
They are called quick connect fittings, they speed up the assembly process. They are defineatly not a quick dis-connect as many have called them. No special tools needed, I have used needle nose pliers and a little lube to get them apart but anything that will push the lock tabs will work. Be sure to get a new coupling retainer, spacer, and O-rings. They are available at most autopart stores. They come in a couple different sizes, 5/8, 3/4 ect.
Thanks for the illustration, JIM! That explains things so much better!
Are you a Mopar Fan? 'CUDA? I am, I love the 1970 Chrysler Corp. E-bodies the 'Cuda and Challenger. A short five year production run 1970 - 1974 for this body style, but the muscle cars built will live in infamy! Pearl Harbor first and foremost Dec. 7, 1941. Then came the Plymouth 'Cuda and the Dodge Challenger!
Ed
Ed
Push in on the hose and push the locks together at the same time, then pull on the hose.
Look here:
http://www.gates.com/brochure.cfm?brochure=1025
Look here:
Ed
Ed
I see you have your priorities in order
Fixnstuff
11-12-2018 11:23 AM
89Reatta
1997-2006 Expedition & Navigator
17
10-28-2011 05:49 AM
FordTrucksKickGM
12-08-2009 04:17 AM
ptt
03-07-2006 12:05 PM
