Sponsored by: Auxito
front end clunk-still
Old Sep 5, 2007 | 08:25 AM
StephenH's Avatar
StephenH
Originally Posted by steve(ill)
Ford originally made A frames with the ball joints permanent. Ther are now aftermarket ball joints for the bottom. You dont replace the entire arm anymore. I replaced the entire upper arm with the ball joint. As far as i know they dont sell just the upper ball joint. Upper arm is about $85. lowr ball joint $40.
You are right Steve. I'm confusing my car with my truck.
Old Sep 5, 2007 | 10:05 AM
bokker's Avatar
bokker
thanks i will give it all a good looking at. bokker.
Old Jul 30, 2008 | 06:47 AM
Haoleman's Avatar
Haoleman
Are you sure your calipers aren't hanging up? A good sign is hot spots causing shimmy when braking. Take your calipers off and sand off the rust on all contact surfaces where the pad plates slide on the caliper mounts and lube them with the appropriate grease. I have to do this every two years on my Super Duty 4WD. I can tell as there is a clunk when I start up indicating the calipers finally releasing. Helps with gas mileage too.
Old Jul 30, 2008 | 10:39 AM
bokker's Avatar
bokker
hi, its been quite some time since i posted this thread but its great to think that it still shows interest.
i posted for further help and finally found the answer. the main bolts holding the drivers side wishbone onto the chassis were not as tight as they should have been and were causing the knock- movement. thanks bokker.
bokker
Sep 8, 2014 02:31 PM
escapedtwice
Escape & Escape Hybrid
Jul 23, 2013 09:53 PM
rustynuts
Aug 19, 2009 05:50 PM
bokker
3.8 & 4.2L V6
Nov 2, 2006 07:33 AM
