switching from auto to man
Old Aug 31, 2007 | 10:07 AM
JL63's Avatar
JL63
Just wondered if anyone new how hard it would be to switch my truck from a auto to a manual trans...and what it would prob cost at a trans shop...
Old Aug 31, 2007 | 10:32 AM
hoxiii's Avatar
hoxiii
Something like this will be hourly at a shop, and at $100 an hour it;'ll get expensive in a hurry.
You have to come up with a pedal cluster, clutch hydraulics, and a transmission. Depending on if you want a 4 or 5 speed the transmission will cost between $50 and $2500, just for the unit.
To replace the pedals the steering column has to partially drop out, which means the dash has to come part way apart. The clutch master cylinder also has to be positioned and have a hole cut for it in the dash. I'd anticipate 2-3 hours here.
Then the old transmission has to come out along with the flexplate off of the motor being replaced with a flywheel. another 2 hours, plus the cost of a flywheel and clutch.
Then the transmission has to go in, along with the slave cylinder. cost of slave, plus one hour labor.
If your crossmember has to be moved figure on another hour labor.
Cost of a transmission mount.
Now, will your driveshaft fit? If not, plan on $100 to shorten one and 200-300 to retube (lengthen) one.
So if you want a 5 speed with a new or rebuilt unit this could cost about $4500. If you use a used 4 speed, it'd probably still run you at least $1500.
If it was me and i really wanted to do this swap (which i actually am getting ready to do), i'd buy some tools and roll up my sleeves. it'll be a good learning/bonding experience.
Justin
Old Aug 31, 2007 | 11:50 AM
tomw's Avatar
tomw
I'd buy a different truck. To me, the time is just not worth it for such a major change unless the truck has some sentimental value.
As an educational tool, there is a good value. But a lot of frustration at things that 'almost' fit, but need that extra...
Get a donor truck, park them side by side, and then you can swap parts to your hearts content. Even speedometer the gears in the tailhousing.. To have the stuff fabricated will cost one arm, two legs and your firstborn puppies...
tom
Old Sep 4, 2007 | 11:10 AM
JL63's Avatar
JL63
k thanks for the insight!
4fords
Electrical Systems/Wiring
Jul 16, 2014 02:17 PM
stimy2001
41
Oct 6, 2013 02:51 AM
getnbz
Jan 6, 2012 07:19 PM
maniak88r
Apr 13, 2011 11:34 PM
k_frocken
Nov 10, 2002 11:50 AM
