Where do you set your timing?
Old Sep 1, 2007 | 01:00 PM
mattri's Avatar
mattri
Where do you like to set your timing? I have an 87 f150 4x4 just curious where everyone else is running, matt.
Old Sep 1, 2007 | 04:37 PM
80broncoman's Avatar
80broncoman
Where it runs the best. And no that is not a trick answer. Turn it up till it rattles and then back it off a few degrees so it won't rattle.
Stock specs are for stock cars going to the grocery store.
Old Sep 2, 2007 | 07:56 PM
mattri's Avatar
mattri
LOL that's where I've been setting it, just figured someone might have a more "scientific" method, guess not. If it ain't broke... right?
Old Sep 2, 2007 | 08:42 PM
Traderjoe28's Avatar
Traderjoe28
FYI - the rubber hub inside the harmonic balancer on the front end of the crankshaft has a nasty habit of slipping, which throws the timing mark on the rim way off when you try to check it like "normal". At #1 TDC on my '87 I6, the timing mark is positioned at the very bottom of the balancer. I time it just like 80broncoman says, and it runs fine.
Old Sep 3, 2007 | 12:44 AM
havi's Avatar
havi
I'll have the Roast Duck
Did the same. found tdc, white markered the zero point, then bumped it to 6 btdc, ran fine, bumped it to 8 btdc ran better, but copped out at higher rpm throttling, so i backed it to 6 btdc. i have an 85 block, 79 dist. and duraspark, and a non egr carb 1bbl. the non egr going to an egr spring in the dist i think is what throws it off between my two settings. I just live with it, it is a plow truck afterall, lol.
Old Sep 3, 2007 | 09:02 AM
Silver Streak's Avatar
Silver Streak
Cranking in the timing until it rattles then backing it off doesn't work on the EFI engines. They make best power between 14 and 16 degrees depending on what fuel you run, but they won't start knocking until you get over 25. On my truck the difference between 14 and 18 degrees on the dyno was about 10hp in favor of 14 degrees.
Old Sep 4, 2007 | 11:35 AM
tiap's Avatar
tiap
Is that base timing with the "spout connector" unplugged???
Old Sep 4, 2007 | 12:30 PM
Silver Streak
Yes it is.
Old Sep 4, 2007 | 01:47 PM
mattri's Avatar
mattri
Good to know, thanks for the heads up silverstreak. I haven't re-set the timing on this truck yet, all the others were carbed, I'll deffinetly keep that in mind.
Old Sep 4, 2007 | 03:41 PM
Wynn96's Avatar
Wynn96
Good I thought maybe I had mine set way high, but it's at 16* and I run nothing less than 92 octane. Guess I'm safe after all lol
Old Sep 4, 2007 | 04:29 PM
Alex2507's Avatar
Alex2507
I just moved my timing from 9 to 12 and happened to have a vacuum guage hooked up. Seemed like my vacuum went from 17 to 20. I live close to sea level. A long time ago a mechanic told me that you could set the timing with a vacuum guage. I use an Accel coil and recently threw in plugs gapped at 46 because somewhere on this forum I read that you need to gap them a little wide to take advantage of the stronger coil. Between all that and going to mid grade gas I seem to be getting 22.5 mpg as opposed to 18 mpg unless of course I didn't quite fill it all the way up. It sounds like it's too good to be true.
