Where do I put it? (be nice now)
Old Aug 30, 2007 | 10:59 AM
kawa's Avatar
kawa
Where does the Probe/pick up for the Pyrometer install? Do I have to drill and tap the Exhaust Manifold? (Sure hope not)
Roger
Old Aug 30, 2007 | 11:02 AM
Neal 97 250's Avatar
Neal 97 250
That is the most accurate place. IMO. I have mine mounted in the DP, since there was a hole there any way, for convenience. I plan on moving mine to the manifold soon.
Old Aug 30, 2007 | 12:31 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Yeap in the exhaust manifold (pre-turbo) here it is:
Old Aug 30, 2007 | 12:35 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Old Aug 30, 2007 | 12:56 PM
ruger761's Avatar
ruger761
i mounted mine in the up-pipe directly after the manifold
Old Aug 30, 2007 | 05:29 PM
kawa's Avatar
kawa
Thanks for all of your input. I just ordered the 3 guage kit from Dieselmanor.
My only other concern (s) is that the photo's supplied do not actually depict my '97 PSD so it's leaving some of the decision up to my interpertation.
One such concern is the "T" that is installed in the 1/4" line on the passenger side of the engine that ends near the A/C unit. I think that I have located it and if I'm wrong no real damage is done.
Thanks again for your input. Without this forum and your input I just don't know what I would spend my money on.
Thanks again.
Roger
Old Aug 30, 2007 | 08:22 PM
ckal704's Avatar
ckal704
It is not that hard to drill and tap the manifold. I drilled mine straight up so the chips fell down and away from the hole. Likewise while tapping. i am sure a couple of fragments fell into the manifold pipe itself, but that was like 10,000 miles ago and i am sure they have passed by now (just like that little piece of bone in your McDonalds hamburger passes!)
Old Aug 30, 2007 | 08:27 PM
ckal704's Avatar
ckal704
Here is a write up I did after installing my gauges. Maybe it will help too.
https://www.ford-trucks.com/forums/4...ighlight=gauge
Old Aug 30, 2007 | 09:02 PM
kawa's Avatar
kawa
Roentgeep:
This photo is from the bottom looking up, Right? (Gawd I hope so)
And......thanks for the other links, as soon as my equipt. gets here I'm ready to fly. (I think)
Roger
Old Aug 30, 2007 | 09:06 PM
c00nhunterjoe's Avatar
c00nhunterjoe
thats the drivers side looking up, the left of the pic is the ft driveshaft, the orange wire is your block heater
Old Aug 30, 2007 | 09:21 PM
barebackjake's Avatar
barebackjake
i like mine in the downpipe so im getting the average of both cylinder banks. ive run probes in both pre and post and they stay consistant. and with my current setup i cant get the truck hot enough to start melting pistons.
Old Aug 31, 2007 | 10:05 AM
Neal 97 250
I removed the y-pipe and drilled and taped it for boost.
Old Aug 31, 2007 | 03:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Originally Posted by kawa
Roentgeep:
Roger
Yes sir, no problem. In the other links there are more pics of the exhaust manifold.
Old Aug 31, 2007 | 09:34 PM
kawa's Avatar
kawa
Neal:
I don't know the names of all the parts yet so....is the "Y"-pipe that gizmo that sits behind the fuel filter that has a 1/4' rubber hose attached and ends near the A/C unit?
I think that it was Dieselmanor that stated in there turbo kit they have included a "Y" connector to be placed within that 1/4" hose then attached that connection to the turbo guage.
By the way....just what is boost? I've looked everywhere and can't find an explanition. I know that you guys know.
Thanks in advance for you inputs.
Roger
Old Aug 31, 2007 | 10:08 PM
c00nhunterjoe
the "Y pipe" is the stock turbo outlet pipe, i nolonger have one i have an "X-pipe" but here is a picture of it, the "Y-pipe" is in the same spot
