390 heads
Old Aug 29, 2007 | 05:30 PM
zap389's Avatar
zap389
390 heads
does anyone know if these are any good? ... CASTING # C1AE-A .....VALVE SIZES ARE 1.55 EXHAUST ... 2.02 INTAKE ....71-74 CCS ..INTAKE PORT SIZE 2.34X1.34 EXHAUST PORT SIZE ..1.84X1.28 .THESE HEADS ARE COMPLETELY REBUILT ... HAVE HARD SEATS INSTALLED IN EXHAUST ..FOR TODAYS GAS . WITH NEW STAINLESS STEEL EXHAUST VALVES ...GUIDES HAVE BEEN CHECKED AND REPLACED AS NEEDED .. ....VALVE JOB HAS BEEN DONE ..HAVE INSTALLED NEW VALVE STEM SEALS .. WITH STOCK DOUBLE VALVE SPRINGS . SURFACED FACE .010 ....SURFACED EXHAUST ..TO FLUSH
Old Aug 29, 2007 | 07:04 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
They are original lowriser heads with std size valves. Not a performance head but will run well on a stockish build. That sounds like an ad you copied from somewhere?? What are they asking for the heads? There might be better options depending what your end use for them is.
Old Aug 29, 2007 | 07:50 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Yep Glenn is right.... There not a bad head..but just not a good head , depending on if your going stock,,or trying to get a little more out of the build...
And Glenn knows what my choices are for useing stock heads...If your going to go with a larger cam and intake..and bump the CR up a tad....The best I have found to run are the C4AE-G's....and have Hardened Ex Valves put in them...CJ size....and some mild port work will go along way with some port matching... JMO..
G, I think I forgot how to build a stock Motor??? LOL
RJ
Old Aug 30, 2007 | 05:31 PM
zap389's Avatar
zap389
Thanks for the help. The ad is on ebay $389 is the buy it now price. Building a street strip motor for my truck. Do have any suggestions for heads,intake,cam, and carb. Stock crank and pistons as far as i know but only 3k miles on rebuild.
Old Aug 31, 2007 | 09:20 PM
RapidRuss's Avatar
RapidRuss
Well .. what kind of change are you looking to spend on this project? lol..I know everyone want all the bang for the buck..we all do...and how much HP are you wanting to build....I know the Most with the least amount of money "right" LOL..
RJ
Old Sep 1, 2007 | 08:00 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Do you have a complete engine now or just a shortblock? What exhaust?
Old Sep 2, 2007 | 07:12 PM
zap389's Avatar
zap389
Talking
Looking for 400-500 streetable hp. I have time to build the motor so money should not be a problem. I have a complete motor but it is a stock 2bbl from a 71 station wagon. I am putting this in my 84 stepside. Any suggestions welcome.
Sick6
Ford Truck Parts for Sale
Jul 5, 2016 11:52 AM
ScallyWaggler
Jun 5, 2015 11:12 AM
Bowtie_Schmowtie
May 9, 2011 06:57 PM
novadragman2005
Feb 11, 2006 12:42 PM
jaydgraff
18
Oct 13, 2005 06:05 PM
