Anyone need any parts?
on
1 Post
OK I've got...
Several complete original frames, the flathead is all there, still in the panel truck hooked to the trans, it even has the breather. I also have several 55 grilles in pretty good shape. email me directly at trucks1956@yahoo.com
I have a 1955 Ford F-100. I need a frame X member. It would be located directly under the seat area. The emergency brake cable passes through it. The X member will have a hole dead center for the emergency cable. I'm also in need of a emergency brake handle clevis. It's attached to the emergency brake by a pin and cotter key.Thanks garyf1955.
on
1 Post
That was me......Had sent you an e-mail from NETSCAPE........
If it's salvageable and the core is good, I'm interested....
Pictures would be nice.......
I'm not in a big hurry to get the heater.....
Have one but don't believe it came in the truck originally.....
Thanks.....
John
Thanks.....
John
Truxx 1956....That's a very nice random act of kindness on your part, to send me that clevis for the cost of the shipping. So please let me know where to send the money and I'll drop you a $20 spot, that should be more than enough to cover the shipping and whats left over you can buy a can of coffee or ? for your shop or garage......Now that the business end is done, I have a tech question. I dropped the original rear end so I could cleanup all the components, replace bushings--coat with Por-15 and install Poly Liner between the leafs. Even though I marked the springs L&R, I didn't realize that from the center bolt to spring eyelets are 2 different lengths. Which end goes toward the cab, the long or short end?.......Thanks garyf1955
