Sponsored by: Kumho
parking brake
Old Aug 29, 2007 | 07:47 AM
Texas Charlie's Avatar
Texas Charlie
parking brake
99 ;; F350 crew cab diesel ... I read a lot about the front brakes but nothing on the rear. I had a recall on this truck when it was new and they redid something on the parking brake. The pedal would be all the way to the floor whenever it did catch. I asked about an adjustment and they said there was no adjustment on the parking brake. When I back my boat in the lake I am afraid I am going to run in someday...someone know how to adjust this brake?
Old Aug 29, 2007 | 04:43 PM
Texas Charlie
I guess I should not have put this where it belongs...should have put it on the diesel side. Maybe someone would tell me I put it in the wrong spot but I would have gotten an answer. Don't know how to move it over there or I would. Thanks!
Old Aug 29, 2007 | 10:33 PM
Gevans17's Avatar
Gevans17
F250-550 super duty
Parking Brake Shoe and Lining Adjustment
<meta content="Parking Brake Shoe and Lining Adjustment" name="tps_proctitle">
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
  1. Remove the brake adjusting hole cover from the backing plate.
  1. Turn the brake adjuster screw to expand the parking brake shoe and linings until they drag against the drum-in-hat rotor.
  1. Back off the brake adjuster screw until no drag is evident.
Old Aug 30, 2007 | 05:41 AM
Texas Charlie
Thanks Gevans17 But I have a few ????
Do I turn the brake adjuster screw up to expand or down. ??
Are there just parking brake shoes or linings other than the brake pads ??
I can find a lot of info. on the front brakes - pictures - & all that ;;BUT nothing on the back ... does any one have pictures?? Thanks!!!
Old Sep 5, 2007 | 10:40 PM
Gevans17's Avatar
Gevans17
If you remove the rotor, you will see the parking brake shoes. To adjust the shoes, remove the rubber plug in the access hole on the lower back of the backing plate. Doesnt say which direction expands the shoes.
Old Sep 5, 2007 | 10:45 PM
Gevans17's Avatar
Gevans17
Texas Charlie
check your email
Old Sep 6, 2007 | 07:54 PM
Texas Charlie
Gevans17 ;; Thank you very much.
Hope you get my reply -- e-mail
Dmntxn77
Feb 25, 2012 09:06 PM
wagonerkl
Jun 21, 2010 10:14 PM
61 uni
May 23, 2009 06:01 AM
Ford94
1997 - 2003 F150
Sep 23, 2001 09:11 PM
