Sponsored by: Kumho
power steering pump problems
Old Sep 4, 2007 | 02:12 PM
clunker86's Avatar
clunker86
i have an 86 f250 that used to have a 6.9 in it, 4x4. i pulled my truck along my trailer today in the shad to do some primming and when i went to park it back along the road my steering got real hard. so i drove it around a few minutes and when i went to turn i had to man handle it. the pump is screaming bloody murder. so i parked it and checked the fuilds and they where fine. idealing it doesnt make the nosie as bad but idealing it around 15-2500 rpms and turning the wheel is loud. i checked the hoses and they where all in good shape. i just recently replace my pitman arm seal because it was leaking too fast to keep power steering fuilded in there over night.
what i need to know is would it be better to spend 45 $ and replace the pump or 16$ and rebuild it. and how hard would it be to rebuild the pump.
thank you
paul
Old Sep 5, 2007 | 06:36 AM
cujo8's Avatar
cujo8
I rebuilt the pump in my 77 F150 and it was a fairly stright forward project, but you do need a PS pulley remover/installer to get the job done. My PS pump is probable a little different than yours though, but I'm sure the process is not all that different.
Old Sep 6, 2007 | 05:19 AM
clunker86's Avatar
clunker86
i went a head and bought a new pump in hopes to having the truck run the next day for the ol lady.i worked 10 and came straight home to jump under the hood. well i got the pump and brakets out before sun set. i went to rumover the hex bolt from the center of the pully and hell came. i been soaking the hex bolt for a good bit in prep and during trying to remove it. well i say its been there since 81 and never been turned. got it a 1/4 to 1/2 way out and snap and a see powder come around the shocket. i thought a broke my hex bit but nope it won. now the hex bolt is craked in 4 nice spots not allowing me to get torq on the bolt for removale. i thought of welden and old hex drive in there and finish rmoving the bolt. do you think that would work and can i put just a regular bolt back in its place?
thank you
clunker86's Avatar
clunker86
thank you
Old Sep 6, 2007 | 05:20 AM
clunker86's Avatar
clunker86
Cool removing hex bolt from power steering pully
thank you
Old Sep 6, 2007 | 06:39 AM
cujo8's Avatar
cujo8
Do you have a picture of your set up? The way my PS pump was set up there was no hex bolt, but a shaft that you had to remove the pulley from using a special PS pulley puller. Are you sure that was a hex bolt that you broke? What does your replacement pump have on the end of the shaft? Good luck.
Old Sep 6, 2007 | 06:40 AM
cujo8's Avatar
cujo8
Sorry about the double post, but this website has been acting up lately. I have not been able to use the web links I receive in my email from this site for the a couple of days now.
Old Sep 6, 2007 | 06:57 PM
clunker86's Avatar
clunker86
i was looking at the wrong thing. i took it to work today and we got to looking at the new one and the shaft on the power steering pump has a hex insert where the bolt screws into it. well now knowing that and that it takes a special tool i will know better then trying to use a 3 jaw puller also. i messed my pully all up. now i am trying to find another one which i hard when you live in the middle of no where. i called ford, advance, auto zone, napa, and even lmc trucks no luck.
Old Sep 6, 2007 | 08:30 PM
cujo8's Avatar
cujo8
Well do you know why I know about your PS pump problems, because I did the same thing you just did years ago, at least using the three jaw puller part anyhow. You can buy just a power steering pulley puller like I did originally, only later did I find I needed a PS pulley installer as well. I then bought a complete PS pump pulley remover/installer. I would check eBay, the classified section of this site, or Mikes Truck Parts for the pulley you need.
Old Sep 6, 2007 | 09:11 PM
clunker86's Avatar
clunker86
yea i talked to my buddy when he stopped by at work and i told him what i did. he was like i got two of them one here and one at home. he was like 6 hrs too late. too bad he didnt work this week.
i think by the time i find a new pully he should be off vaction and he'll let me use his so i dont have to by one, but i will some day down the road so i can have one in my tool box.
yea i tried looking all over today for the pully. i look at fte sponsor last night and had no luck. i bumped into a buddy a few mins ago at walmart and he said to try broncograveyard.com. i find it hard that people dont sell parts for these ol fords. well hope i find one soon.
