Sponsored by: Auxito
battery light on
Old Aug 28, 2007 | 04:49 PM
ohiofordnut's Avatar
ohiofordnut
Unhappy battery light on
hi i have a 1997 f150 the battery light stays on i bought a new battery a new alternator { i bought a new ford replacement one } but its still stays on
any suggestions thanks john
Old Aug 28, 2007 | 05:24 PM
steve(ill)'s Avatar
steve(ill)
check the ground wires to the body, motor and frame. poor ground will make alternator do that. also check output with a seperate volt meter.
Old Aug 28, 2007 | 05:25 PM
ranger88a's Avatar
ranger88a
Check power to the alt. and regulator. You may have a blown fuse. O/lb,should have power key off, lg/r, should have power when running.
Old Aug 28, 2007 | 07:52 PM
ohiofordnut
Smile battery light
i found the problem there was a terminal that wasnt making good contact thanks everyone
