Alternator problem v.3.2 Rectafier
Old Aug 28, 2007 | 02:52 PM
John311t's Avatar
John311t
So I got my alternator back today, and the rectafier(im not sure if its spelled right) was bad? Was causes these to go bad? I can understand the bushings, the bearings and such but how does a rectafier go out, and what is a rectafier?
Old Aug 28, 2007 | 03:04 PM
nlemerise's Avatar
nlemerise
A rectifier is a device which converts alternating cuurent (AC) into direct current (DC). The alternator produces AC current and it must be converted to DC to charge batteries and run accessories.
Old Aug 28, 2007 | 03:06 PM
fbilly420's Avatar
fbilly420
useing your alt. to charge low batteries can ruin a rectifier.
Billy
Old Aug 28, 2007 | 04:45 PM
SpringerPop's Avatar
SpringerPop
Diodes (rectifiers) go bad for usually two reasons only:
1. They get real HOT.
or
2. They pass too much current, which causes them to get hot, which causes them to fail (see #1).
There is actually a third reason, which is getting subjected to a voltage past which they were rated, but that's almost never a reason in automotive applications.
Pop
Old Aug 28, 2007 | 05:19 PM
nlemerise's Avatar
nlemerise
Originally Posted by Sprin
SpringerPop
Pop
Hey Pop...I got a question for you . I thought a diode was a one way valve...lets current run one way, but not the other. So a rectifier is the same as a diode? I always thought a rectifier took AC to DC and an inverter was DC to AC. If you are too old to be too smart, I am too old to be so dumb!
Old Aug 28, 2007 | 05:35 PM
SpringerPop
First, let me clarify why an alternator uses diodes. It's a three-phase AC generator with diodes to rectify that AC into DC. It uses six diodes in its rectifier pack to do this, two for each phase. If any of them go bad (either short or open), youse gotsa' problem! An open diode gives you reduced output capacity, but a shorted one gives you a blown fusible link or smoke! OK so far?
A diode is a component. It's a stand-alone device that passes current in one direction, and blocks it when the current attempts to go the other.
A rectifier is usually defined as a device which turns AC into DC. It's usually some kind of assembly, and may (and usually does) contain more than one diode. But, if the purpose of your rectifier is to turn single-phase AC into half-wave-rectified DC, then one diode is enough to be called a rectifier.
For our purposes here, rectifiers will contain diodes, but not the other-way-around.
Pop
Old Aug 28, 2007 | 08:19 PM
nlemerise's Avatar
nlemerise
Pop
I got it! Thank you oh knowledgeable one ,
Old Aug 29, 2007 | 01:52 AM
indebt's Avatar
indebt
Well mine went out because of a bad (loose) connection causing it to get hot and fail. So now that I have my newly rebuilt one in there I am checking those connections every 6mo from now on to make sure they are tight!
powerstroke1869
May 6, 2011 01:44 PM
dvcroket
20
Mar 28, 2011 06:50 AM
k150
1997 - 2003 F150
13
Feb 10, 2009 06:47 PM
F450 Aaron
Aug 30, 2006 08:50 PM
mrskat41
Jul 6, 2003 08:14 PM
