Alternator keeps going bad
Old Jul 6, 2003 | 03:50 PM
mrskat41's Avatar
mrskat41
Question Alternator keeps going bad
I have a 1988 Ford F-250 with an inline 6. I had an electrical place check my truck out . The only thing they could see wrong with it was my alternator was bad. I have replaced it 3 times.
Its like my truck has no power. It will only run about 40mph.
Does anyone know what could be causing my alternator to go out?
Old Jul 6, 2003 | 04:16 PM
1987LTDmasta's Avatar
1987LTDmasta
this is a very odd desription. '88s had an internal voltage regulator so it cant be the voltage reg.
are you even sure the alt is going out?? make sure your voltage is above 13.5 volts.. if its that or above, no more than 16 Volts, then the alt is still good.
I dont know what else to tell you. its hard to understand the problem that your having without a better desription of whats going on
Old Jul 6, 2003 | 08:14 PM
Silver Streak's Avatar
Silver Streak
Change the fuel filter and check the catalytic converter and muffler. Low power is a classic symptom of those three things. I have never seen a bad alternator cause a vehicle to be limited to 40 mph.
g4551
6.4L Power Stroke Diesel
Dec 19, 2016 11:43 AM
88_F0RD
Dec 6, 2016 07:53 AM
Macrosill
Nov 27, 2015 04:43 AM
maximumd93
Mar 11, 2013 09:52 AM
Donald Rohret
1983 - 2012 Ranger & B-Series
Oct 14, 2003 06:39 AM
