Sponsored by: Auxito
Knocking in engine
Old Aug 28, 2007 | 02:38 PM
flyingcarl's Avatar
flyingcarl
Knocking in engine
I have a 97 f150 4.2L V6 XLT manual transmission with 105,000 miles. Recently I went out to start my truck and it immediately started knocking. I have not driven it since other than to put it into my driveway. I was not haveing a problem before and the knocking came on all of a sudden. I do think I might have had a small coolant leak somewhere. Also white smoke is coming out of my tail pipe. The knocking does speed up when the engine is accelerated. It would be great if there was anyone in Va Beach who could come listen to it. I want to fix it myself but I worried I will have to pull the engine out. I don't have that kind of room or capabilities. Any assistance would be greatly appreciated.
Thanks
Carlton
Old Aug 28, 2007 | 08:48 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
Sounds like it may have gotten coolant down into a cylinder and possibly bent a rod.
I would pull the plugs and turn it over to see if any antifreeze blows out of a plug hole. If so, then it will probably need a rebuild or new shortblock.
Old Aug 29, 2007 | 08:25 AM
lee_eldridge's Avatar
lee_eldridge
I agree with LxMan1, although I don't think you need to pull any of the plugs to confirm what's going on.
You're definitely eating up water if there's white smoke. You definitely have a spun bearing or bent rod if you hear knocking.
If I were you, I'd find a clean motor from a junk yard and swap it out. You may be able to find a 5.4L & trans combination for pretty cheap, in which case that would be a nice upgrade.
Old Aug 30, 2007 | 01:45 PM
flyingcarl's Avatar
flyingcarl
Apperentlythe wrist pins on the pistons are known to wear out on these engines. Ford knew about it and has corrected the problem for future engines. Unfortunately for me it is $2600 for a mechanic to fix it. Ouch!
Thank you for your assistance.
Old Aug 30, 2007 | 03:05 PM
Club Wagon's Avatar
Club Wagon
Bad wrist pins will not cause you to have a "small coolant leak somewhere" or have "white smoke is coming out of my tail pipe". However a serious coolant leak into a cylinder could easily bend a rod or ruin a wrist pin, but you should also have water in your oil. Either way. Ouch!
Might be worthwhile to roll the dice on a recycled 4.2 for much less than $2600. You could buy another pickup for that kind of cash!
Old Oct 26, 2007 | 02:28 PM
eo1mays's Avatar
eo1mays
Hello. I am new to this forum and don't the correct area to inquire. I have a 1998 F150 with a bad 4.2 liter V6 motor probably due to the coolant leak in the engine. I have heard a lot of talk about rebuilds and remanufactured. My question is that if I am going to replace the motor should I stay with a 4.2 or is there another size that would bolt to current transmission. Any help would be appreciated.
Old Oct 26, 2007 | 02:46 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE eo1mays! You would be best to stay with the 4.2L V6. Good luck!
Old Oct 26, 2007 | 03:49 PM
eo1mays's Avatar
eo1mays
Thanks KingRanchMan02. If I get the reman will that solve the problem of the bad gasket? I would hate to run into the same thing down the road.
Old Oct 26, 2007 | 04:02 PM
KingRanchMan02
Ford fixed this problem around the 2000 model year. Any remanufactured engine should be updated with new gaskets. It should be a question that you ask of whoever you buy a engine through.
Old Oct 27, 2007 | 07:10 AM
Dozerbob's Avatar
Dozerbob
I have a 98 4.6 4x4. Did a super flush on coolant and all hell broke loose. New water pump, radiator, thermostat. Now burning oil, loosing coolant check engine light going crazy. White smoke also. All that time the mechanic kept saying no signs of head gasket leakage. Now look at what I got broke motor.
buddy357
Apr 3, 2013 06:35 AM
terrybrisco
Virginia Chapter
Nov 30, 2012 04:50 AM
wulfman
Aug 29, 2011 05:24 PM
FxRiZBeAsTLy
Oct 31, 2010 02:53 PM
Edman
1983 - 2012 Ranger & B-Series
Mar 10, 2008 07:17 AM
