water in fuel light??????????
Came on and went off...ran for a while and now came back on..also no issues with the way it is running...no way there can b water in the fuel....i dont think...here is the problem...the plug for draining it out waspreviously stripped pretty bad by the knuckle head who took it out...now I cant get the plug out...anyone have any ideas? Also will changin the frame mounted filter do the same thing as pulling the drain plug....just trying to figure a way out to get the water out of there without puilling the plug....thanks
that's a good question. i'm not sure if changing the filter would accomplish that, but it's sure worth a try. i would buy the replacement drain plug that has a knurled fitting for using your hands/pliers OR the allen wrench, it's not much money under twenty bucks i think, and i'm sure someone here will post a link to it for you.
If it turns out there isn't any water in there it's covered under the 5yr/100K mi warranty. Mine started coming on intermittently. I'd drain it and there'd be no water, light would stay on then go off for no reason. Finally came on and stayed on. Ford dealer changed it out under warranty. Best case though is you just have a little water that needs to be drained.
If you actually have water in your fuel it should be caught by the fuel/water separator (HFCM). If that's the case just drain it and go about your business. Now if it was a substantial amount of water I would consider draining the tank and replacing the fuel/water separator. If it's not too much I wouldn't worry, that's what it's there for. Truck should run just fine as long as the separator is doing it's job.
Originally Posted by LvTitan
you should try reading the whole post, then you would see what his question was.
Originally Posted by buckshot047
any ideas what I should be experiecing if thereis actually water in the fuel? Trucks is running grea....im a little confused
Originally Posted by hawaiianrockscaping
Has anyone else had a BAD problem w/ water in the gas tank. The Ford svc dept changed my entire fuel system - from the gas tank to the injectors and within a month there was water in the tank again. They can't figure it out!
are you filling up from the same station ? try getting your fuel somewhere else.
FYI, it's a fuel tank, we dont run gas
And the gas tank/fuel tank thing...that's been the hardest habit for me to break I think! I still say "I need to stop and get gas" and such. I just hope I don't actually wind up WITH gas one of these days!
My '03 did the same thing. I changed both filters, removed the code, but the water in the fuel light came back on again. After fretting about it for over a week, I talked to one of the older guys in my lodge who owns a repair shop. He suggested it was actually the fuel itself, which according to him, the formula has been changed from what used to be available, that causes some of these truck to throw a code for water in the fuel.
Now I dont want to start a pissing war, but he suggested I put a quart of tranny fluid in the fuel tank. I asked if he was serious? He smiled and said thats what they used to do years ago to get the water out. His explanation is that the tranny fluid would lub the injectors and cure the water indication. I pondered this for a while, but his reputation conviced me to try it... this was 6 months ago. It took about 2 days for the problem to magically go away, but it worked.
Like I said, I surely dont want to start a war by this suggestion, only telling you what worked for me.
