4.5l Duramax
4.5l Duramax
Will be interesting who makes it to the diesel 1/2ton market first...
http://www.autobloggreen.com/2007/08...ax-diesel-v-8/
(and more importantly, who gains the most sales out of it)
I enjoy the different approach to engineering this engine in regards to the design of the heads, and the exhaust. It makes sense to build a turbocharged V engine in this manner. After all with current V8 turbo diesels the turbocharger (giant heat sink) is still in between the cylinder heads basically on top of the intake runners, where it can heat up the charge air that just had to get cooled off in the intercooler.
Originally Posted by BLK94F150
I wonder if it's possible to not refill the urea thing and not set off a million idiot lights. That's just one more thing that I'm not going to want to fill up for $3/gallon.
Mike
Mike
Originally Posted by FTE Fred
I thought that was a good idea too.
The industrial turbo'd V12 Cummin's at work all have the same set up, just makes... sense.
Originally Posted by duramaximizer
I agree, everything is better with the intake exhaust location, but remember, the engineering goal was to make it fit in the same area that a small block fits. Therefore, where would you put a turbo besides in the V of the block?? Remember, the left and right banks both now have air intakes which would create a heat inbalance in Left vs Right. So that would be worse than equal heat in both sides of the motor....would it not?
That is my thought on the charger anyway...the center keeps heat, airflow and turbulance the same for both sides. Besides, what happens when you put a bigger turbocharger on it than the stock one. You don't want to have to worry about porting a head different just so it flows right.
Heat imbalance would stem from different airflow, I am talking left to right EGTs, not Coolant temps. JMO.
