Sponsored by: Real Truck
front axle oil ?
Old Aug 27, 2007 | 11:28 PM
f150_514ci's Avatar
f150_514ci
front axle oil ?
hi i have a 2002 F350 4x4 and would like to know what oil goes in the front axle. thanks
Old Aug 27, 2007 | 11:32 PM
Nikolai's Avatar
Nikolai
Should be 80w-90.
Old Aug 27, 2007 | 11:36 PM
f150_514ci's Avatar
f150_514ci
Originally Posted by Nikolai
Should be 80w-90.
ok just wanted to make sure it wasnt synthetic . i know the rear says synthetic on the one axle tag but wasnt sure about the front. thanks
Old Aug 28, 2007 | 01:22 AM
steve604's Avatar
steve604
80w90 is good enough for the rear end too. i believe the only reason ford started the 75w140 thing a few years ago was to get slightly better gas mileage out of it so they could put a better epa mileage rating on the truck when it was new on the lot.
this is also the reason for 5w20 motor oil recomendations in the gas engines which actually causes engine wear but better gas mileage.
Old Aug 28, 2007 | 03:35 AM
Nikolai's Avatar
Nikolai
So what engine oil should us 5.4 owners be running?
Old Aug 28, 2007 | 07:03 AM
995.4SD's Avatar
995.4SD
i use royal purple 10-30 in my 5.4.
as far as front axle, book says 75-90, rear is 75-140. i use royal purple ith those as well.
I don't know why they changed to 75-140 but it sure wasn't to get better MPG. going to a thicker oil will not give you better MPG.
Old Aug 28, 2007 | 07:23 AM
redford's Avatar
redford
FTE Leadership Emeritus
From the owner's manual.
Your engine should have Motorcraft SAE 5W-20 Premium
Synthetic Blend Motor Oil
Your front axle should have a Hypoid Gear Oil SAE 90.
Your rear axle should have Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
Here's a URL to the manual. Lube recommendation chart is page 234.
http://www.analogstereo.com/pdf/om/f...anual_2002.pdf
Old Aug 28, 2007 | 08:06 AM
vettdvr's Avatar
vettdvr
<TABLE style="WIDTH: 631pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=840 border=0 x:str><COLGROUP><COL style="WIDTH: 91pt; mso-width-source: userset; mso-width-alt: 4425" width=121><COL style="WIDTH: 80pt; mso-width-source: userset; mso-width-alt: 3913" width=107><COL style="WIDTH: 64pt; mso-width-source: userset; mso-width-alt: 3108" width=85><COL style="WIDTH: 72pt; mso-width-source: userset; mso-width-alt: 3510" width=96><COL style="WIDTH: 92pt; mso-width-source: userset; mso-width-alt: 4461" width=122><COL style="WIDTH: 78pt; mso-width-source: userset; mso-width-alt: 3803" width=104><COL style="WIDTH: 154pt; mso-width-source: userset; mso-width-alt: 7497" width=205><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 91pt; BORDER-BOTTOM: #ece9d8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=121 height=17>Front Diff</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 80pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=107>Gear oil</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 64pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=85></TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 72pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=96>Ford Spec</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 92pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=122>XY-75W90-TQL</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 78pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=104>WSP-M2C201-A</TD><TD class=xl24 style="BORDER-RIGHT: #ece9d8; BORDER-TOP: #ece9d8; BORDER-LEFT: #ece9d8; WIDTH: 154pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent" width=205>75W90 HP Axle Lube</TD></TR></TBODY></TABLE>
Old Aug 28, 2007 | 09:29 AM
redford's Avatar
redford
I see that for the later years (like 2006) but the 2002 manual calls for the Hypoid Gear Oil SAE 90.
Old Aug 28, 2007 | 10:16 AM
krewat's Avatar
krewat
Uh, no, there were lots of Sterling failures early on, when they went to synthetic, it stopped.
Old Aug 28, 2007 | 10:45 AM
vettdvr's Avatar
vettdvr
Rear Diff Gear oil 8 Pint F1TZ-19580-B WSL-M2C192-A 75W140 HP Synthetic Axle Lube
Lubermatic OEM Synthetic 70w 140 States on label meeting spec.
Rear Diff Limit Slip additive 35 ft lbs 1/2 Pint 16 oz C8AZ-19B546-A
EST-M2C118-A
TransX Limit Slip Tube states on label meets spec
Old Aug 28, 2007 | 11:13 AM
995.4SD's Avatar
995.4SD
my 99 manual says 75-90 for the front, weird.
Old Aug 28, 2007 | 11:24 AM
redford's Avatar
redford
I'd go with the 75-90 also, I just wonder why they didn't call for it in the 2002 manual?
Old Aug 28, 2007 | 12:47 PM
steve604's Avatar
steve604
i bought my 2000 f250 sd with a 5.4 from a ford dealer with 60,000 miles about 9 months ago and it had 5w20 in it at the time. on cold starts the lifters would make alot of noise for a minute and when it would warm up at idle there was a slight knock from the engine. not sure if it was piston slap or what. at the first oil change i put in quaker state 10w30 and the engine hasn't made a sound since i started using that. i've changed the oil 4 or 5 times since then.
i had an f150 with a 4.6 before this truck and used nothing but 10w30 qs for it's whole life and never had a problem with engine knocks or ticks and i sold the truck with close to 200,000 miles on it.
Old Aug 28, 2007 | 12:54 PM
vettdvr's Avatar
vettdvr
Smart move going to 10w30.
