Sponsored by: Real Truck
front axle oil ?
Old Aug 28, 2007 | 01:19 PM
f150_514ci's Avatar
f150_514ci
thanks guys.
Old Aug 28, 2007 | 01:45 PM
Ronin007's Avatar
Ronin007
Originally Posted by steve604
80w90 is good enough for the rear end too. i believe the only reason ford started the 75w140 thing a few years ago was to get slightly better gas mileage out of it so they could put a better epa mileage rating on the truck when it was new on the lot.
this is also the reason for 5w20 motor oil recomendations in the gas engines which actually causes engine wear but better gas mileage.
The reason for the 5W20 oil recommendation was due to the modular engines having closer tolerances than engines in the past. The early V10's came with 5W30 as the recommended oil and was changed to the 5W20 when the PI heads came out in 2002 if I recall correctly.
Old Aug 28, 2007 | 04:46 PM
vettdvr's Avatar
vettdvr
IMO 5w20 was used to lower fluid resistance and improve CAFE rating at the expense of engine life. (5w30 or 10w30 will have the opposite effect but your fuel consumption will hardly show on just 1 vehicle)
The internal clearances on the engines haven't changed much. Years ago main bearings would have clearances of .001 to .002 and today they can't get much tighter. However the manufacturing process to control statistical variation has improved so more parts will be exactly the correct size and raw materials have improved. This helps make the engines more consistant and will also reduce oil consumption. However $$ is the driver for Detroit and lower viscosity oils will allow more gas hogs (read suv's) to be produced at higher profit.
The new oils are killers on older engines that dont' have a roller tappet cam. Some of the new oils will destroy a cam and lifters in less than 30,000 miles if they aren't roller tappet. So if you do have an older car make sure you use the older oils. However most new cars do have the roller tappet because this also improves CAFE.
But these are just opinions and your opinion may vary.
djmichael24951
29
Nov 11, 2015 07:49 AM
remj93
May 2, 2015 04:02 PM
USMC0351fordtruckin
Large Truck
13
Sep 24, 2014 11:04 AM
Snuggyworm
Jul 30, 2014 11:35 PM
IDIDieselJohn
Jun 18, 2014 10:51 PM
