Just curious what kind of tires i can put on the stock 20" rims on my Harley edition. I kinda like the stock rims just want to know if i could get a little more agressive tire on it.
I have 35x12.5R20 Toyo Open Coutry M/Ts on my factory 20's (they aren' the Harley's but close enough). I have a slight rub at full left turn on my trailing arm that I should be able to fix by adding a little material to the steering stop. Just haven't had time to do it yet.
I believe that these tires should fit your truck without a lift, but you will probably have to pull back the plastic fender liners a bit.
I bought mine from Marty at Truck Toyz Performance (he is a sponsor here, and his member name is Overkill). He was pretty much the only one in the country that had any when I was buying them. He did give me a good deal though. I would definitely suggest talking to him.
