Does everyones Tranny leak or just mine?
Old 08-27-2007, 01:19 PM
superman64011's Avatar
superman64011
superman64011 is offline
I got a 55 Ford. 460/ C6 combo. I have a small Tranny leak somewhere. Seems like it is coming from the Transmission Oil Pan Gasket. Ive had a gasket. Then I used some gasket maker silicon. It leaks after about a month. Its not leaking alot but after about a month it has a 3X3 ft Tranny oil residue on my floor. Does anyone else have any probs like this. It is annoying the heck out of me.
Patrick
Old 08-27-2007, 01:33 PM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
It is a bother. My Fordomatic had a leak where the selector goes in the side. I finally had to pay a shop $150 to put in a new seal. But now there is no more leak. Jag
Old 08-27-2007, 01:35 PM
superman64011
I had a Tranny Shop rebuild it before I built the truck. It frustrates me. Thanks for your Feedback.
Old 08-27-2007, 01:50 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
What year model C-6 is it? Ford had some problems around 75-76 with the C-6 leaking fluid around the front pump. The 460 and C-6 in my 79 came from a 75 and if I park it nose-down for a week, I'll have to add fluid before it will move. There is a gasket and O-ring kit to fix this leak.
Old 08-27-2007, 02:10 PM
Huntsman's Avatar
Huntsman
Huntsman is offline
My AOD also leaks at the selector, have a new o-ring for it but haven't taken time to put it in. I'm really dreading pulling the pan again but I am planning on using one of those vacuum pump gizmo's this time. Last time I had transmission oil in three counties before it was finished.
Old 08-27-2007, 02:18 PM
superman64011
Not sure on the make. Tranny Shop said someone put a different tail shaft on it to lengthen it up. Is the Vin on the Tail shaft toward the back. Thats the only one i saw. Just looked.
Patrick
Old 08-27-2007, 02:26 PM
jareddill's Avatar
jareddill
jareddill is offline
not that it helps, but my 4L60E leaks, as does my mazda 5spd, my wife loves me
Old 08-27-2007, 02:36 PM
superman64011
Ugghh. Thanks Jared.
Old 08-27-2007, 03:54 PM
jareddill's Avatar
jareddill
your welcome, and on another note be careful when you wash down your driveway, the fire department might show up, and block your street for i dunno, maybe two hours, or more, not that has ever happened, no my neighbors dont really like me
Old 08-28-2007, 07:10 AM
54-4U2C's Avatar
54-4U2C
54-4U2C is offline
Another way to think of it is that it's not really leaking, it's just marking it's territory.
mytoys2037
06-17-2013 11:40 PM
dyoungen
06-03-2013 05:15 PM
Carnes99
Modular V10 (6.8l)
02-06-2013 01:22 PM
heybrent
1978 - 1996 Big Bronco
08-17-2003 02:31 AM
Quick Reply: Does everyones Tranny leak or just mine?
