2002 explorer o2 sensor question
Old Aug 27, 2007 | 07:39 AM
michaelmueller's Avatar
michaelmueller
Question 2002 explorer o2 sensor question
Hey guys, I have a 2002 explorer that occationally throws a o2 sensor down stream bank 1 code, it is not causing any drivability issues and the light goes out after a short while and it will not come back on for weeks sometimes months. My question is, instead of just replacing the suspected faulty o2 sensor, is there a way to check and possibly clean the faulty o2 sensor? I'm kinda cheap when it comes to throwing coin at somthing if I don't have to.
thanks for the help.
mike
Old Aug 27, 2007 | 08:48 PM
elmo8641's Avatar
elmo8641
what is the code number. there are alot of o2 codes. could be rich, lean, a heater code. give me a code number and i would be able to help out more
Old Aug 29, 2007 | 09:59 AM
michaelmueller
sorry it took so long to get back, the code # is PO136, faulty o2 circiut, its the bank 1 down stream o2 sensor. Like I said, the light only comes on once in a while for a brief period of time and then it goes out for quite awhile. I know it is a 4 wire sensor so it could be a number of things, I just wondered if it was serviceable (cleanable and testable).
Old Aug 29, 2007 | 03:03 PM
elmo8641's Avatar
elmo8641
well with the check engine light only coming on once in a while it will be hard to trake down. prob need to replace the sensor, but if could be a wire problem. sorry could not give better info but with it only happening sometimes it will be hard to diag the exact problem.
Old Aug 30, 2007 | 06:36 AM
michaelmueller
thanks for the replies, I am heading out of town for a week so I replaced the sensor last night, just for piece of mind.
Old Aug 31, 2007 | 09:41 AM
Bear River's Avatar
Bear River
Former ******
That was a good idea, O2 sensors should be replaced once in a while anyway. I sell catalytic converters, and the number one thing that causes them to fail is bad O2 sensors, and most bad O2 sensors do not trigger codes. They just stop giving ACCURATE signals.
KsCop
Dec 26, 2014 07:17 PM
rainman19154
Escape & Escape Hybrid
Sep 13, 2014 11:40 AM
Luke80916
Jan 29, 2012 12:46 PM
idlewild
1983 - 2012 Ranger & B-Series
Jun 30, 2011 06:01 PM
svtcobra041
1997 - 2003 F150
Jul 15, 2010 09:19 AM
