Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
O2 sensor code
Old Aug 24, 2014 | 05:46 PM
rainman19154's Avatar
rainman19154
O2 sensor code
2004 XLT 3.0L 141K
I just bought the truck on Monday, the CEL popped up on Tues.
It shows code 0136. No other codes. CAT "not ready" on scan tool
A google search proved this is a common topic that for some owners is a repeating and cronic sort of issue. What I've read online is that there is an assortment of things that can cause this O2 sensor to throw this code:
Actual bad O2 sensor
Faulty wiring or connection
Misfire throwing mix off
bad convertor
I don't believe this list covers all the accounts I read but these I have were definitely repeat offenders.
My intention is to take to a dealer and let them have first crack at sorting it out. I'm handy enough but I see this as something where an unseen detail can drive ya crazy.
Anyone have any opinion or experience with this?
Old Aug 28, 2014 | 12:42 PM
Max Capacity's Avatar
Max Capacity
The truck is 10 years old, don't take it to the dealer, unless its the dealer you bought it from, only because its under warranty.
Find a good local repair shop, ask around the auto parts stores who they would trust to work on there cars.
IMO you most likely have a bad O2
I googled it for you.
https://www.google.com/search?hl=en&...74.fIdtKJ44_1A
http://www.obd-codes.com/p0136
Old Aug 29, 2014 | 09:09 AM
tomw's Avatar
tomw
This is the 'checker' O2 sensor that sits downstream from the 1st O2 sensor and also the converter. It makes sure the converter is not putting out yucky stuff, and tattle tales on a failing converter. "who checks the checkers? ... dunno"
Any way, it just sits there and monitors. Yours is producing 0 volts vs the .1 to .9 that is expected. It may have bad wires, a bad heater, or be non-functional totally.
I would expect that the seller, if a dealer, would have at least a 30/30 warranty that would apply - 30 minutes after you sign, and 30 feet out the door .. Worth a check to see if they'll stand up to it if applicable. Here, the seller must provide up-to-date emissions sticker, if a dealer, I think.
Anyway worth also looking under the truck, at the wires & O2 that are mounted after the cat for obvious reasons it will not produce any juice. Broken wires or loose connectors can be cured relatively cheaply. The O2 might swap with the upstream sensor to see if it is totally dead or just playing possum. The code would follow a bad O2.
tom
Old Aug 29, 2014 | 03:34 PM
rainman19154
Thanks for a little more thorough analysis.
Yeah your 30.30 assessment of the used car warranty is pretty much on target. As IS, no warranty. Like it or not.
This is about par for me and used cars. Almost always, something to shake out and then I drive them until there's nothing left to avoid having to repeat the whole experience.
I get my money's worth, generally driving my 'daily driver' well into the 200000s. This one is starting off a little worse than most but not THE worst. (not yet)
Old Sep 13, 2014 | 11:40 AM
WB4IUY's Avatar
WB4IUY
Hahahaha.... 30/30 warranty :-) Love that one.
Dave
tseekins
2009 - 2014 F150
Dec 5, 2018 10:14 AM
neumayr83
1983 - 2012 Ranger & B-Series
Sep 10, 2012 06:33 AM
TigOldBitties
Modular V8 (4.6L, 5.4L)
Mar 15, 2010 11:00 AM
biederboat
1978 - 1996 Big Bronco
Dec 8, 2009 06:32 PM
94F150Shorty
Oct 18, 2004 01:37 PM
