Sponsored by: Real Truck
wrench shaped warning light on..
Old Aug 26, 2007 | 03:56 PM
edmunster's Avatar
edmunster
what does it mean when engine has defaulted to a limp home mode ....6.0 f350 2005....thanks guys for the help
Old Aug 26, 2007 | 04:15 PM
CounterMaker's Avatar
CounterMaker
limp home mode means something serious could be wrong...if im correct the truck wont let you get over a certain amount of rpm's/speed to prevent something getting torn up in your engine...just get it to the dealership ASAP and dont drive fast!!
Old Aug 26, 2007 | 04:28 PM
edmunster's Avatar
edmunster
wrench shaped warning light--
truck runs fine ......but the light comes on after i drive about 25 miles or so.
Old Aug 26, 2007 | 04:40 PM
Drumfish's Avatar
Drumfish
There is a reason for the light.
Better to be safe than sorry, I would get it to the dealer, it should still be under warranty and it is not worth waiting. It might be a bad sensor, but In my experience the notification lights are not there for giggles....
Best Luck..
Old Aug 26, 2007 | 04:46 PM
CounterMaker
ya probably a sensor but dont take the chances...park it untill you can get it to the deaaler
Old Aug 26, 2007 | 05:03 PM
redford's Avatar
redford
FTE Leadership Emeritus
That's the "Damn, I hope this thing is still under warranty!" light.
Old Aug 26, 2007 | 09:22 PM
duffman77's Avatar
duffman77
Wrench shaped light is for the fuel water seperator on diesels. It needs to be drained.
Old Aug 27, 2007 | 05:52 AM
Monsta's Avatar
Monsta
Sit. Stay.
That light being lit and "Limp Home Mode" are two totally different things.
Old Aug 27, 2007 | 06:59 AM
msgtg's Avatar
msgtg
Stu....as usual...LMAO!
If I'm having one of those days....just look for one of redfords posts...it'll get better after that!
Joe
Old Aug 27, 2007 | 01:04 PM
johnnysF350's Avatar
johnnysF350
The wrench light means that there is a problem with your electronic throttle. The accellerator is controlled electronically now, no more cables. Usually the truck will default to a limp mode when the light comes on but I would get it checked out ASAP because if it goes out completely you may get no throttle input.
Old Aug 31, 2007 | 11:39 PM
DCMAC's Avatar
DCMAC
I had the same problem, wrench light on my '06 6.0 PSD. I took it to the dealer and he showed me a service bulletin that instructed reflashing of the engine computer as the solution. They did that and I haven't seen the wrench light since.
dadstruck
16
Feb 23, 2025 06:53 AM
jowilker
Nov 10, 2012 10:43 AM
May 3, 2002 01:31 AM
Flash
1997 - 2003 F150
Mar 24, 2002 10:12 PM
RRL78
1978 - 1996 Big Bronco
Oct 17, 2000 12:10 PM
