driveshaft removal
Old Aug 25, 2007 | 08:45 AM
rtcalabrojr's Avatar
rtcalabrojr
Darksider
driveshaft removal
I have to take out the driveshaft in my 92 f350 4x4.
I tried to slide the yoke out of the transfer case but it started to leak oil. how much oil will come out? What should i do? Thanks RT
Old Aug 25, 2007 | 09:33 AM
F150xlt's Avatar
F150xlt
If the truck is level, nothing should leak out.
Look at the transfer case fill plug. That's how high the fluid should be.
Old Aug 25, 2007 | 09:44 AM
Talyn's Avatar
Talyn
Thats not nessarly true F150xlt.
They make plugs to plug the output shaft. I have a custom made one out of some exhaust stuff, for when my drive shaft broke.
Just throw a bucket under there, and catch what comes out. It sounds like its full if you have a little bit of ATF comming out.
The fill line is just above where the output shaft comes out to lubricate the seal and the yoke. I doubt you would get more then a cup or 2 of atf out of there.
If it looks nasty, Change it out. =)
T-cases need love too.
Old Aug 25, 2007 | 11:06 AM
rtcalabrojr
Darksider
Thanks for the help. i only lost about a tablespoon of oil out of the t case. RT
Old Aug 25, 2007 | 11:32 AM
grizz3000's Avatar
grizz3000
Are you removing the driveshaft OR the yoke?
Pulling the driveshaft out of the yoke shouldn't cause any leakage.
Old Aug 25, 2007 | 01:27 PM
F150xlt's Avatar
F150xlt
He said only 1 teaspoon came out. I guess his transfer case was low on fluid?
Old Aug 25, 2007 | 01:52 PM
rtcalabrojr
Darksider
Grizz, i removed the drive shaft.
F150xlt, I said i lost a TABLESPOON not teaspoon.
Old Aug 25, 2007 | 03:09 PM
Talyn's Avatar
Talyn
As long as fluid is touching the flange, it is correct. The transfercase will cause the fluid to expand further to coat completely during use.
I made a guess on how much should come out. However I know that the fluid should come out when you remove the yoke.
nothingbutford46
1983 - 2012 Ranger & B-Series
Jun 14, 2013 10:04 PM
fowler250
18
Mar 10, 2008 06:24 PM
stephenfaustin
Feb 13, 2008 03:57 PM
WALFORD'S 56
Oct 24, 2007 02:58 AM
84-250
Jun 28, 2006 05:21 AM
