3speed driveshaft same as 4speed driveshaft??
Originally Posted by WALFORD'S 56
thanks----that will save me a hassle. I will keep eye on a driveshaft for a 4 speed. thanks again!!!! Bill
N.D.---I brought a 272 yblock and 4 speed back from Connecticut,for ksmith in March. He just notified me that I could have it and the tranny .....I know it was froma 1956 FORD F600 272 2 barrel and 2 speed eaton rear. I have the frame now as that is my cummings swap truck ....I thought if I could put that into a F100 frame and hook it up,but need a driveshaft. I have an extra F600 2pc driveshaft left-over would that be usable? The new F100 is 110'' wheelbase and so nice to finally work on a F100 instead of F600S..........thanks N.D...........Bill
Dumb question: Would this apply for my 1959 f-100 with a 292? I'm trying to find a transmission but I can only get a 4 speed instead of my 3, on the column. Will I need to grab that driveshaft off of that truck? Does it matter if it is a long or short box as well? Sorry for stealing your post.
If you're changing to a 4-speed then yes you'll need to grab that driveshaft as well.
It does matter if long or short box. The long box shaft will be 8" longer than the shortbed shaft.
So if you have a longbox shaft going into a shortbed truck you'll need to shorten it 8".
Just the opposite for a short shaft into a longbed, you'd need to extend it 8".
I think the 3-speed driveshafts were all one length for both long and shortbeds, the difference was made up in the transmission tailshaft length, according to my Ford truck shop manual, it shows the 3-speed tranny with extended tailshaft but does not for the 4-speed.
So I may be wrong here, I assumed the 4-speed shaft was longer for the longbeds, 8" difference in wheelbase it has to be made up somewhere, but I have nothing to compare to so I can't be 100% sure on what I told you earlier.
I know the 3&4 speed shafts hook up to the trannys differently, the 3-speed yoke slips right into the tailshaft and the 4-speed shaft has an extension that bolts up to a flat plate coming off the back of the 4-speed with 4 bolts, therefore the 3-speed shaft won't work with the 4-speed trans and vice-versa.
Bottom line here is if you're swapping from longbed to longbed as you say, grab the trans and driveshaft together off the parts truck, you should have no problems.
While you're at it, I'd swap the steering column too so's I would'nt have a 3-speed column with a 4-speed shifter sticking through the floor, but that's just me!
Originally Posted by My58Ford
I think the 3-speed driveshafts were all one length for both long and shortbeds.
The 110" wheelbase trucks (2WD) have a one piece driveshaft, the 118" wheelbases have a two piece driveshaft.
Examples:
1957/60 F100 2WD 110" wheelbase ~ 3 speed manual: B7C-4605-E .. Driveshaft ~ 63 13/32" long.
1957/60 F100 2WD 118" wheelbase ~ 3 speed manual: B7C-4605-F .. Driveshaft ~ 56 1/8" long AND B6C-4816-A .. Coupling Shaft ~ 21 13/16" long.
Then I wonder why the extension on the 3-speed trans?
Do you know anything about that?
The driveshaft/coupling shaft info I typed above in post #13, is direct from the 1957/63 Ford Truck Parts Catalog.
Cougar54
37
04-27-2017 11:21 AM
86stepsideF150
10-08-2016 11:06 PM
slickside
13
12-05-2014 06:42 PM
hellbilly1932
02-13-2012 11:35 AM
