1978 - 1996 Big Bronco
Odd problem
Old Aug 24, 2007 | 07:13 AM
jbondi's Avatar
jbondi
Question Odd problem
I've been noticing sometimes when I start my truck in the morning, the engine will rev high, the check engine light will flash, then I put it in drive, the rpms fall like the truck is going to stall, then it's fine and the check engine light stays off!! Any ideas??
Old Aug 24, 2007 | 10:25 AM
Kemicalburns's Avatar
Kemicalburns
PULL CODES, www.fordfuelinjection.com has instructions using a paperclip, counting the flashes
Old Aug 24, 2007 | 09:27 PM
blue beast's Avatar
blue beast
If you bump the throttle does the revving stop? Have you ever cleaned the IAC? sounds like its getting stuck.
Old Aug 27, 2007 | 09:15 AM
jbondi's Avatar
jbondi
You mean like in the old days of kicking off the choke? No, haven't touched the throttle when this happens. Are there any write ups on how to clean the IAC??
Old Aug 27, 2007 | 10:05 AM
Kemicalburns
have you gone to the website and read up on there. pull codes etc..
Old Aug 27, 2007 | 10:33 AM
jbondi's Avatar
jbondi
I searched through the articles and couldn't find anything pertaining to the IAC on a Bronco. Haven't pulled codes yet, just wanted to see what was involved with cleaning/replacing the IAC.
Old Aug 27, 2007 | 10:45 AM
blue beast's Avatar
blue beast
It is easy to clean a can of carb cleaner pull off Iac and you should see the plunger in there all gunked up. Spray it liberally until it's nice and shiney. Make sure you hold the motor up or else all that gunk will go back inside it. On a cold start your truck should rev up then a tap on the gas will make it go to a normal idle, or wait 90 secs and it will go down itself!
nosebreaker
Nov 6, 2016 07:54 AM
rbeesley
Oct 29, 2015 03:56 PM
matts156
Jul 25, 2014 02:16 PM
Southpaw2
Modular V8 (4.6L, 5.4L)
15
Feb 10, 2005 07:35 AM
downhomegirl2
Escape & Escape Hybrid
Feb 22, 2004 11:06 AM
