Modular V10 (6.8l)
V10 Power Upgrades
Old Jan 19, 2002 | 06:11 AM
haney2's Avatar
haney2
V10 Power Upgrades
I have a friend that has just bought a 2000 F-350 4x4 V-10 Dually. It is an automatic, 4-Door truck. A very nice looking truck. Since neither he nor I have ever owned a V-10, I was looking for suggestions/experience in adding more HP/Torque.
What is the best add on's for the $$? What I am looking for is a sequential upgrade plan with info on HP/Torque added with each? Anybody have any opinions.... Things like chips, air flow, exhaust, etc.... Also list any Con's of adding the parts.
He often pulls a 4-horse gooseneck with sleeping quarters... I think it is about a 28 ft job....
Thanks for your help.....
Jamie
Old Jan 19, 2002 | 07:00 PM
V10man's Avatar
V10man
V10 Power Upgrades
K&K style drop in air filter.. 3-5 hp $50
Headers 15-30hp $550 +
Cat-back exhaust 10-20hp $300-$500
Computer chip 30hp $300 +
You can mix and match parts, Borla, Gibson for example or go with a full kit like Banks. I wouldn't hold too much stock in manufacturers #'s (except for Banks, they are pretty reliable, close anyway) I don't think I've read any tests that have actually come close to that the companys claim.
Old Jan 19, 2002 | 08:06 PM
FTE Ken's Avatar
FTE Ken
V10 Power Upgrades
Superchips are $300+, Diablo's aren't.
Hot Rod magazine did dyno pulls of the Diablo PSD 100 HP chip/exhaust combo and got 97 HP at the wheel. Pretty accurate, IMHO. Diablo gives numbers that are pretty accurate for the majority of the ECU codes.
Old Jan 20, 2002 | 01:31 AM
DirtySideDown's Avatar
DirtySideDown
V10 Power Upgrades
Ken says
Ken is that the FLY wheel or the REAR wheel. If that a rear wheel number that amazing with just a chip change.
:-staun
Old Jan 20, 2002 | 03:32 AM
NoMo's Avatar
NoMo
V10 Power Upgrades
The PSD (all diesels???) can get huge 100+ rear-wheel HP gains from chips. You'll only get 25 to 30 rear-wheel HP from chips in a gas engine.
Old Jan 20, 2002 | 03:44 AM
NoMo's Avatar
NoMo
V10 Power Upgrades
Using V10man's figures for reference...
Another thing to remember is that these "gains" aren't necessarily cumulative. For example, with the above mods, one might think they bought an extra 85HP. In reality, it'd be more like 60-65 HP. This is because the manufacturers install their product on a stock vehicle then quote the highest power gain they see. In reality, once the major power constraints are removed, additional mods have less impact on performance.
Old Jan 22, 2002 | 01:15 AM
V10man's Avatar
V10man
V10 Power Upgrades
Exactly NoMo. I think that is where some folks get confused. They add all these mods then expect tons of power. I added the K&N and cat-back first and saw no increase at all. It wasn't until I added the headers that I actually "felt" any gains.
Old Jan 24, 2002 | 10:42 PM
Monsta's Avatar
Monsta
Sit. Stay.
V10 Power Upgrades
Old Feb 17, 2013 | 01:40 PM
KP1001's Avatar
KP1001
Mike at five star tuning told me to buy one of his programs, get some free flowing mufflers and call it good. I thought about doing this and adding the k&n intake. Also wanted to add 3:55 or 3:73 gears to increase the fuel mileage. What do all of you think?
Old Feb 18, 2013 | 06:13 PM
mikeismadness's Avatar
mikeismadness
I would stick with Mikes tunes and free flowing muffler. I think intakes are way overpriced and not worth the investment. Unless you actually need the extra air flow, which you probably won't. Your truck came factory with 3.73, 4.10, and 4.30 gears. More than likely I'm willing to bet you have 3.73. Going higher in gear ratio probably won't net you much of a mpg gain, and you would lose towing power.
Old Feb 18, 2013 | 06:14 PM
mikeismadness
And a K&N drop in will not net you 3-5 hp, maybe 1 if your lucky.
Old Feb 18, 2013 | 08:20 PM
KP1001's Avatar
KP1001
Thanks for the info.
So you believe the 4.10 or 4.30 would be better even on the highway?
Old Feb 18, 2013 | 10:16 PM
jerem0621's Avatar
jerem0621
I seriously dislike putting a oil bath air filter in my truck..
Just put a regular paper filter on it..
Honestly, the best thing you and your friend could do is to replace the plugs, coil boots and springs, fuel filter, and change the fluids.
Thanks!
Jeremiah
Old Feb 19, 2013 | 08:22 PM
KP1001's Avatar
KP1001
Thanks!
Jeremiah
What are "coil boots"?
Old Feb 25, 2013 | 04:56 AM
wpnaes's Avatar
wpnaes
Rubber boots connect the coil to the spark plug (theres a spring under that boot). See blue tube in the photo. They age and crack over time which can cause a misfire. No need to replace the coil until they go bad.
sawmaned
Jun 11, 2017 01:45 PM
Brentw1984
Apr 27, 2016 06:38 PM
Blue Rebel
19
Aug 13, 2010 10:14 PM
geoaigel
23
Jun 1, 2008 10:08 AM
scottjohn
Sep 22, 2002 01:06 AM
