Power steering?
Old Aug 23, 2007 | 03:54 PM
kitteekate's Avatar
kitteekate
Power steering?
Is there a way to find where a leak is in the power steering? my truck wont keep the power steering fluid in.
Old Aug 23, 2007 | 04:10 PM
blue68f100's Avatar
blue68f100
First inspect your hoses for leaks. If your leaking that bad it should leave oil on the pavement. If not, have someone crank it from lock to lock while your underneath looking for leaks.
Old Aug 24, 2007 | 07:50 PM
losttxn's Avatar
losttxn
at your autoparts store you can buy a dye that you can see with an ultra vilot light.
Old Aug 24, 2007 | 08:50 PM
blue68f100's Avatar
blue68f100
Not very may person have the black light for dye. Beside if it's leaking that bad it should be easy to find.
Old Aug 24, 2007 | 10:01 PM
RNOVRIT's Avatar
RNOVRIT
Use some oven degreaser to clean the area and wipe down the pump and hoses. Then run it for a little while and see where the wet spot is.
Old Aug 24, 2007 | 10:30 PM
losttxn's Avatar
losttxn
Lightbulb
black light cost approx $15 in the A/C section. dye cost around $5.
Old Aug 24, 2007 | 10:34 PM
75F350's Avatar
75F350
Holy smoke guys, just look for where the dirt is collecting. A clean line will not get dirty. One that is leaking will have all kinds of dirt all over it.
A/c leaks, look for a collection of dirt. Oil leak from the pan, look for dirt, leaking differnetial, gonna have dirt on it. You get the idea.
Any component that has oil in it, and also has a collection of dirt on it, is leaking.
A big leak will make drops on the ground, but a leak that does not mark its spot, might just have an accumulation of dirt that will not let it drip,,,,,,yet.
stepside
Mar 12, 2002 10:13 AM
bjoern
Aug 9, 2001 01:20 AM
otto
Feb 1, 2001 09:33 AM
jowilker
Feb 15, 2000 08:41 PM
BigBrownTruck
Oct 27, 1999 12:35 PM
