cruise control issues
Old Aug 23, 2007 | 10:15 PM
tmdrum's Avatar
tmdrum
tmdrum
My clock spring went out which affected my cruise control, airbags and horn. I had it replaced and everything worked fine.
Old Aug 23, 2007 | 10:17 PM
tmdrum's Avatar
tmdrum
Check your clockspring
Old Sep 12, 2007 | 11:40 AM
Pocketrocketz1's Avatar
Pocketrocketz1
I'm having issues with my cruise on my 2000 Excursion as well. I bought almost two months ago....It worked great with no issue and now the "cruise" light comes on, but immediately goes out and the cruise isn't working. Someone on here told me to check the clock spring, but I'm not having issues with my horn. I say that because it just seemed that the clock springs were bad if the horn wasn't working.....Does someone know where i can go to get a maintanence Manaul or just instructions on how to do this job?
I'm wondering if my parking brake has something to do with this because I vaguely remember my cruise working and then after I used my parking brake, it didn't. My brake light isn't on, but I sort of feel my brakes sticking after disengaging them.
Anyway, I want to rule everything out before i tear my steering wheel off.
Old Sep 12, 2007 | 12:38 PM
F250_'s Avatar
F250_
There is a brake pedal sensor that may have gone bad. Check that too.
Old Sep 12, 2007 | 12:45 PM
Pocketrocketz1
That's what my father in law said, but I'm not sure where to find it.....anyone have any pics so we can check it out?
Old Nov 14, 2008 | 04:03 PM
adrianlovessnow's Avatar
adrianlovessnow
I just took my 03 7.3L in to the dealer and had them diagnose the cruise. They check switches, pressure switch and the sensor on the rear dif and came to the conclusion that it is the abs module / ecu under the dash. the part number they used was 5c7z2c219b to the tune of about $500 this may be simular to what is going on in your truck. My ABS light dosent stay on or anything like that. So it is a thought. Good luck....
