Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
backlights in instrument cluster
Old Aug 21, 2007 | 08:26 PM
dragonz118's Avatar
dragonz118
Yesterday I started my car and my primary backlighting to the instrument cluster would not light up. I have checked all of the fuses and visually checked all of the light bulbs in the back of the cluster, all of which seemed fine. The owners manual says that if the instrument cluster will not light to bring the vehicle into the service center, but I am fairly sure that is to replace the bulbs, but maybe I am wrong. If anyone has any ideas of what could cause this please let me know as any help at this point would be greatly appreciated.
Old Aug 22, 2007 | 01:10 PM
gasman6674's Avatar
gasman6674
Dumb Question
Did you check the panel dimmer and the fuse?
Old Aug 22, 2007 | 04:41 PM
dragonz118's Avatar
dragonz118
I just checked the dimmer and that seemed to work alright, but then I checked fuse 18 which is for illumination and found that no power was going to it. I looked over the wiring diagram and now believe that the problem is the relay that sends power from the switch to the instrument cluster fuse.
Old Aug 23, 2007 | 12:03 AM
dragonz118's Avatar
dragonz118
well the relay turned out to be fine, so after all of this I am forced to believe that the real culprit here might be the multi-function switch at the steering wheel. I have no idea how to go about testing the switch as of yet and would appreciate any input into a test procedure for the headlight multi-function switch
Old Aug 23, 2007 | 09:26 PM
aj7885's Avatar
aj7885
lights instrument cluster
It appears the Escape uses a microprocessor for the instrument lamps. Fuses feeding it are a 5amp, and 3x10amps. I have 2 pdf files of the connectors and schematic if you want them. Enter an Email and I'll send them ASAP.
chaostoday
Sep 2, 2012 07:56 AM
Biggg72
Jan 11, 2011 10:41 PM
gecko03
1983 - 2012 Ranger & B-Series
Jan 29, 2005 08:09 AM
neufelda
Mar 31, 2004 08:21 AM
Kevin
Jan 4, 2000 12:19 PM
