Oil temp
Old Aug 22, 2007 | 06:20 PM
MR5x5's Avatar
MR5x5
Tunes and gages.
http://www.edgeproducts.com/product....roke+Evolution
Old Aug 22, 2007 | 06:32 PM
Izzy351's Avatar
Izzy351
Here's the thing -- do the "gauges" on that package read from the PCM? If so, it's not a good solution because our trucks defuel at 25psi and require a fooler of some kind to keep the PCM from seeing the higher boost. The one I have (ITP Overboost Annihilator) limits the PCM to 22psi. That display would be useless just when you needed it most. Now, I say all that assuming there's not a separate boost sensor for it. If there is, then you're good to go.
Regarding Jody's tunes... Oh yeah, they're worth it!!
Joe
Old Aug 22, 2007 | 10:12 PM
jtharvey's Avatar
jtharvey
The PCM does take it's readings from the back of the HPOP res. I also have an Autometer gauge in that location to monitor my oil temps. I typically see a peak of 240, but it's almost always over 220 when fully warmed up. Using the AE software, I notice my factory EOT reports a little lower than what the Autometer does, by about 10 degrees. Could be your stock EOT sensor is going bad.
