1973 302 ignition timing
Old Aug 20, 2007 | 10:14 PM
73f100shortbed's Avatar
73f100shortbed
I just finished putting motor back in truck after doing rear main seal, and other gaskets, and a timing set. Motor was set at TDC. Starts up and runs well. Good idle. I would like to get the timing set. I don't have an emission sticker under hood and my book says to refer to it. What should I set the timing at and does it have to be done with vac. advance hose plugged? Thanks for the help.
Old Aug 21, 2007 | 10:31 AM
Mil1ion's Avatar
Mil1ion
The book says 6* BTDC 600 rpm with Vacuum hose to dist disconnected and plugged
Old Aug 21, 2007 | 12:25 PM
Keepin It Real's Avatar
Keepin It Real
Mil1ion, I am curious about what book you get this info from. I, too, have a '73 F100 with the 302. The factory manual (engine) says to see the specification book which says to see the decal which is also gone. I got (from where I don't remember) 12BTDC and the PO has it marked that way on the harmonic balancer (?). I know you have right info so I'm going with 6BTDC. Just curious where it comes from. Did Ford not expect their trucks to outlast the decal?
Old Aug 21, 2007 | 12:33 PM
rjent's Avatar
rjent
IMHO, the best way to time an engine is to remove the vac hose from the dist and run the engine at around 3500 RPM while using a timing light with the delay wheel on the back (or a timing tape on the balancer) and set the total mechanical timing at about 34* to 36*. Then hook up the vac and road test it on the highway with the engine at highway speed. If you feel a little surging the timing is a little fast and back her off a little.
Hope it helps!
Old Aug 21, 2007 | 03:24 PM
Mil1ion's Avatar
Mil1ion
The book is Peterson's FORD ..Tune-up & Repair
Ford's Lincolns and Mercury's since 1970
ISBN0-8227-5041-4
I looked at the specs again and noticed a reference #14 which is If 6*BTDC doesn't work.....refer to engine decal.
I also have this though .
http://www.clubfte.com/users/mil1ion...e-upSpecs.html
Old Aug 21, 2007 | 06:38 PM
Keepin It Real
OK. Good to know. Thanks.
Old Aug 21, 2007 | 06:43 PM
Mil1ion's Avatar
Mil1ion
http://cgi.ebay.com/Softcover-Peters...QQcmdZViewItem
Old Aug 21, 2007 | 10:38 PM
73f100shortbed
Thanks Mil1ion. I will start at 6 and see what happens.
Old Aug 21, 2007 | 11:23 PM
woodbutcher05's Avatar
woodbutcher05
On the 74 F100 that I had with 302,I set mine at 10*btdc.Worked great.And when I swapped in a DS2 setup,used the same setting.Also worked great.
Leo
Old Aug 22, 2007 | 08:02 AM
BigShelby's Avatar
BigShelby
Manual Trans, 302 should be at 10 degrees. I'm running at 13 right now for a little added power after converting the ignition over to Pertronix. Runs great. Also running 93 octane to account for the increase in timing.
Old Aug 22, 2007 | 09:06 PM
73f100shortbed
It's set around 7 degrees right now and is running better then it used to so I'm gonna see how that goes for now.
Modz
17
Feb 23, 2026 11:18 PM
sibernut
Jan 22, 2016 05:13 AM
free59mod
Nov 23, 2015 10:29 PM
rsm688
Jun 24, 2015 06:54 AM
Robrt32
Apr 25, 2014 10:17 PM
