Dual alternator setup ???????
Old Aug 20, 2007 | 07:00 PM
mrxlh's Avatar
mrxlh
Anyoone have pics of a factory dual alt setup? I am pruley guessing, but the second one mounts below the cac tube does it not?
Old Aug 20, 2007 | 07:05 PM
npccpartsman's Avatar
npccpartsman
Does it show a dual alternator belt routing under the hood of your truck?. I actually think it's on the right front corner of the engine under the other alternator (I'm going by my fuel return regulator instructions). Other than that I'm just guessing. My truck isn't here or I'd go look.
Old Aug 20, 2007 | 08:55 PM
Kep4's Avatar
Kep4
Jäger
From the passenger side:
From stright above:
Old Aug 20, 2007 | 09:42 PM
mrxlh's Avatar
mrxlh
OIC said the blind man............Didn't figure that they piggybacked the belts like that. Then it really makes no sense to try to accomidate the s-tine belt then. Thanks a ton Russ for the pics, it clears up alot and routes me in yet another direction.
Old Aug 20, 2007 | 09:44 PM
mrxlh's Avatar
mrxlh
Russ, what pulley is the second alt piggiebacked off of? And if it is possible without too much trouble can you get a pick of it without tearing half of the truck apart?
Old Aug 20, 2007 | 09:56 PM
bneafus's Avatar
bneafus
Ryan, I went out and took a look...Seems to go around the flywheel or main drive pulley.....and 3 idler pulleys!! Go figure. It'll be very hard to get a pic. I only figured it out with the belt routing diagram on the fan shroud. I can try a pic of that if it helps....Brian
Old Aug 20, 2007 | 10:28 PM
mrxlh's Avatar
mrxlh
That figures. Idler and a tensioner if I had to guess. I looked at the routing diagram on my 6.0 and didn't make much sense of it. Let me look again.
Ok on edit, I see that the dotted line in the diagram is the second alt belt routing, wow what a Charlie Foxtrot this is going to be to figure out.
80ford100
Jan 22, 2017 06:32 PM
1995droptopz
Jun 29, 2016 10:14 PM
Meats12
17
Jun 11, 2015 12:56 PM
jrodimus
Jan 16, 2010 07:18 PM
76hi-boy
24
Mar 24, 2005 11:21 PM
