Speedometer error
Old Aug 22, 2007 | 02:30 PM
speedrdr's Avatar
speedrdr
a VERY simple way to check to make sure that your speedo is indeed off by 15 percent is to find a road with mile markers (or have someone mark a mile) and set your speed at 60 mph(sorry, don't know kph) and time the mile exactly. if you're not covering the mile in 60 seconds then for certain your speedo is off. mine is off by 20 percent making 50mph be 60mph. if you know that you're 15 percent off, then take the speed sensor unit out of transfer case(if a 4x4) and remove the plastic gear and count the number of teeth. then you can get a replacement gear that has 15 percent more teeth(i think it's 2 teeth) and this will get your speedo back at the correct reading. or you could do like i do and just remember how much you're off and drive it like that. LOL
speedrdr
352Ford
Jun 10, 2014 09:36 AM
F4WineGuy
15
Dec 12, 2011 10:27 AM
aRKToS
Sep 27, 2009 05:50 PM
mh_merc
1947 and Older Ford Trucks
56
Aug 31, 2009 11:12 AM
Nic
Aug 18, 2003 04:46 PM
