HI, Im running a dyno simulator for my 400, and im finding that porting the exhaust valves to the same size of the intake valves in a stock milled head would give me like 150 more horse power ( stock valves: int 2.04" vs ext 1.66"). Is it posible to port the exhaust valves in a stock head to 2.04" ? IN my dyno says it wont affect that much low end torque, what would the consequences be ?
pretty sure the physical layout in the cylinder head prevents making the valve openings any bigger than 1.72 or so. even if you could cram a bigger valve in there, it would be so close to the cylinder walls so as to shroud itself and not provide better flow.
you're better off improving flow though the exhaust ports in the cylinder head. experiment with your head flow exhaust numbers in your dyno program to see what i mean...
Dyno sims do not predict physical limitations. The cylinder walls shroud the exhaust valves, so that there is not much improvement in flow above 1.65" in exhaust valve diameter. All aftermarket heads limit the exhaust valves to about that size for this reason. Opening the port and increasing the short radius of the bend, remove any flashing, and polishing the port will give your as much flow as you can get.
So you are saying that staying with the stoock head and porting and polishing it makes a real difference? What else can be done with the heads if the valves are already maxed out to get better performance? ED
So I should increrase my exhaust valve to 1.72" and enlarge/polish my exhaust port in the head nad whats increasing the short radius of the bend? what´s the bend ? sorry for my ignorance
There is no advantage to increasing the size of the exhaust valve.
The short radius is the radius of the bend of the port between the valve seat and the outlet of the head. This is a sharp bend. You want to reduce the shapness of this bend, so that exhaust will flow smoothly around the bend.
Exhaust wants to follow a straight path and not bend.
