High mileage V10 questions
You may think I'm nuts but I picked up a '99 F-250 Lariat SC 4x4, in pristine condition for way cheap (7k under kelly bb)but it has 100k on it. Now I'm not too scared about the mileage since it had all the service records and with the $$ I saved I can afford a rebuild on a tranny or block. But I have some questions on the V10 since I have been reading the problems people have.
1.Since the motor has reached this point (100k) w/o the piston slap problem or a plug blowing out am I out of the woods as far as these go?
2.After reading all I can on the plug blowouts it appears it may be caused by a mis-threaded plug on change or from bad machining when built. I want to replace them myself now so there is only me to blame if a mis-thread occurs. Now these plugs look way different just looking at the top end, any special procedures here? What is the box looking thing on top of them??
3.I eventually want to put on a Banks system but have some concern about a header on an aluminum head, will this cause excess heat buildup that could lead to a head problem - spark plug blowing or other??
4.Finally, has anyone heard of issues on the V10 after it reaches high mileage like specific wear patterns or common breakage points?
An answer to any or all these questions would be much appreciated. I am going from a Ford 4.0 V6 that has 200k and is as tight and strong as day one, and hoping that this baby will do the same. I'm just a little concerned about this plug business and the fact that the design is relatively new.
BTW - The truck is awesome so far, no oil consumption, no vibrations or rattles, drives and rides like brand new!
I'd say yes- until you change the plugs.
>top of them??
The "box" on each plug is actually the coil for that plug. It should unplug by lifting straight up. To change the plugs, you'll need several lengths of extensions, probably a universal joint (or two), and it helps to be double-jointed. :P
The cast manifold has very little contact with the head. So, all the heat from the port is concentrated around the port. Headers with a solid flange should, IMO, distribute the heat better. The Banks headers have a nice 5/8" thick flange that should resists warping and work better to prevent hot-spots. Lots of RV'ers running them with no reports of problems. I have the full Powerpack on my truck & love it.
>breakage points?
I've heard nothing about high-mileage problems.
As an FYI, the V10 engine has been around since 1997. It was originally used in the Econoline vans and made its way into the trucks in '99 when the new SuperDuty came out. So it's a well-tested design and a good engine.
Yes, I am a maintenance freak with my trucks, everyone is shocked when they learn my little Navajo (2dr Exploder) has 200k with the stock motor and tranny but that is what regualr maintenance does. Now it gets rewarded with being my Colorado rock crawler.
I ended up reading a bunch about the Banks powerpack and decided that is the way to go. I am impressed with their philosophy of air first then fuel in order to increase engine longevity which is what I am all about. I also think you guys are on the right track telling me the heads will actually be cooler as a result of the Banks headers.
NoMo, You said you have the powerpack system on your V10 and love it. Did you get the module and trans command as well?
Looking forward to 200+k on my newest black beauty!
heat. The scavenging effect can lean out the intake charge. An engine
running lean will run a LOT hotter.
If you use a chip to richen up the fuel mixture, I can believe you
could run cooler than stock. Ford uses extra fuel to cool some systems from the factory.
-Jim
