Can you identify this box?
Old Aug 19, 2007 | 07:09 PM
imlowr2's Avatar
imlowr2
I've had several people look at this and have no idea what this steering box is out of. I know it's not a 56 Ford F100. I tried to look for numbers but it's difficult to see without getting close. I did not the casting has a letter "s" on it. (see second pic) and the adjustment plate looks like it may say Ford on it, but can't be sure. Hope the pics help.
Old Aug 19, 2007 | 07:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
That's a Saginaw "S", but beyond that I'm no help. Saginaw parts were used by just about averyone.
Old Aug 19, 2007 | 07:14 PM
sparky's Avatar
sparky
Sort of looks like an early 70's manual steering box..... It looks like the one that was in my 73 F250 4x4 only smaller.
Old Aug 19, 2007 | 07:44 PM
havi's Avatar
havi
I'll have the Roast Duck
I assume the sector shaft comes thru the frame at a "90"?
the rag-joint looks ford to me like I stated before, though I'm not positive.
Old Aug 19, 2007 | 07:55 PM
imlowr2's Avatar
imlowr2
Correct! it comes out of the frame at a 90...
Is Saginaw - Ford?
Old Aug 25, 2007 | 04:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1975 and later Econolines used Saginaw Gearboxes, F Series trucks did not.
Saginaw is a Division of GM, but the gearboxes are used by Ford and other makes.
Old Aug 25, 2007 | 03:17 PM
imlowr2's Avatar
imlowr2
Number- Do you think this is out of an Econoline Van? Where I would find numbers so I can reference this unit. I mainly want to know if this is a good steering box and worth rebuilding or just yank it and go with the Toyota box.
Old Aug 25, 2007 | 03:50 PM
doug51f1's Avatar
doug51f1
Why not just put in a Ford box?
Old Aug 25, 2007 | 06:32 PM
imlowr2's Avatar
imlowr2
The one in it is a Ford box, I'm trying to figure out what Ford it came from. I think your referring to installing the original 56 Box? From what I heard, they are not strong, wear out quickly. There is a reason so many people switch to the Toyota box despite having power steering. Your advice makes sense and would be the easiest way to go. Thanks.
Old Aug 26, 2007 | 10:31 AM
doug51f1's Avatar
doug51f1
Wink
Sorry, I was just trying to be humorous, or as my daughter says a Smar -T- Pants.
