4 bar rear
Old Aug 22, 2007 | 04:20 AM
sid318's Avatar
sid318
Hi deec, you can get adjustable shock plates to weld onto your axle, will give you plenty enough scope to adjust your coilovers, up & down, so won't need to be so precise with length of coilovers.
OLD FORDS NEVER DIE
Old Aug 22, 2007 | 09:00 PM
3Mike6's Avatar
3Mike6
You guys need to mock up the weight..., then mock up the sheet metal...only way to be happy with the end product.
Old Aug 22, 2007 | 09:25 PM
mamelukesword's Avatar
mamelukesword
Coilovers
Coilover setup is one reason I chose airbags. I am not getting fancy with the air setup and it is fully adjustable. My experience with coilovers is limited and they seem very tempermental if not setup correctly.
jbtecnico1
1997 - 2003 F150
Nov 1, 2011 05:39 AM
70XLT
Jan 25, 2004 08:15 AM
rmroost
Offroad & 4x4
Jan 6, 2004 10:52 AM
