Sponsored by: Auxito
How do recalls work?
Old Aug 18, 2007 | 10:55 PM
Club Wagon's Avatar
Club Wagon
Never had anything to do with recalls since all my vehicles have been used & older. The '98 F-150 I'm about to adopt from my Dad will be the lowest mileage vehicle I've ever owned. I presume its among the recalled vehicles in the cruise control switch campaign, but doubt my Dad ever had anything done. He basically lost interest in driving it & it might take a little elbow grease to get it out of mothballs. My questions are:
How to find out about all recalls pertinent to this truck?
Do recalls transfer to a 2nd owner or should I help Dad to pursue it?
Any other major recalls come to mind for '98 F-150 SuperCab 4X4?
Is there a website to dig into this or is it exclusively through the Dealer network?
Is that the VIN on the lower right corner of the Window Sticker above the bar code?
Can I presume the VIN is the key to all recall records?
Old Aug 19, 2007 | 03:40 AM
duggyb's Avatar
duggyb
i dont know any of your other questions...but yes the VIN is located in the lower right window...as well as inside your door on a sticker.
THNX
Duggy
Old Aug 19, 2007 | 06:14 AM
ncranchero's Avatar
ncranchero
1)How to find out about all recalls pertinent to this truck?
2)Do recalls transfer to a 2nd owner or should I help Dad to pursue it?
3)Any other major recalls come to mind for '98 F-150 SuperCab 4X4?
4)Is there a website to dig into this or is it exclusively through the Dealer network?
5)Is that the VIN on the lower right corner of the Window Sticker above the bar code?
6)Can I presume the VIN is the key to all recall records?
1)Field Service Actions (Recalls)
1998 F-150 - US (English)
00L07
Special Field Action - Certain 1998 through 2000 Model Year E-Series and F-Series Bi-Fuel CNG Vehicles - Fuel Door Label Application / Replacement
Published 10/2000
00S14
Safety Recall - Certain Canadian vehicles exported to the U.S. market Daytime Running Lights (DRL), and open safety recalls
Published 07/2000
04L19
Special Field Action - 1997-2002 MY F-150, 1997-1999 Light Duty F-250, 1997-2002 MY Expedition, 1998-2002 MY Navigator, and 2002 MY Blackwood Vehicles Maintenance Reminder - Tie Rod Inspection Procedure
Published 09/10/2004
05S28
Safety Recall - Certain 1992-2004 Multiple Vehicle Lines – Speed Control System Modification
Published 03/08/2007
97S86
Safety Recall - Certain 1997 and 1998 F-150/250 Series Trucks, Expeditions and Certain 1998 Navigators - Automatic Transmission Shift Cable Retention.
Published 10/1997
97S96
Safety Recall - Certain 1997-1998 F-150 Series Trucks with 4.2L Engines Currently Registered in Certain Cold Weather States and Canada - PCV Modification
Published 03/1998
98B33
Owner Notification Program - Certain 1997 and 1998 Expedition, F-150 and 1998 Navigator vehicles equipped with 4.6L and 5.4L engines for inspection of coolant and, if necessary, replacement of engine cylinder heads
Published 04/1999
98R04
Regional Recall - Certain 1997 and 1998 Model Y. F-150 Series Trucks Equipped W/ 4.2L Engine & Currently Located In U.S., Canada & Fed. Terr. Outside The Orig Safety Recall Region - PCV System Modification
Published 04/1999
98S14
Safety Recall - All 1997 and Certain 1998 Model Year F-150/250 (under 8,500 lbs.) Series Trucks, all 1997 and Certain 1998 Model Year Expeditions and Certain 1998 Navigator Vehicles - Wheel Attachment
Published 06/1998
98S18
Safety Recall - All 1997 and Certain 1998 Model Year F-150 4x4 (139 in. or 157 in. Wheel Base) Series Trucks (except those with the Off-Road Option Package) - Rear Spring Clip Installation
Published 08/1998
99E03
Emissions Recall - Certain 1996-1999 Crown Victoria and 1997-1999 F-Series/Econoline and 1997-1998 Expedition with the Dedicated CNG (Compressed Natural Gas) Option; 1998-1999 F-Series/Econoline with the Bi-Fuel CNG Option - Fuel Filler Valve Replacement
Published 10/1999
________________
Documents found: 11
2) Recalls go with the vehicle regardless of previous owners.
3) See complete list above
4) The most reliable info is available from a dealer or someone who has dealer access.
5) The VIN is visible through the lower LEFT (drivers side) windshield and also is on the vehicle certification label on the body just below the drivers door striker.
6) The VIN is the key to all vehicle specific info.
Old Aug 19, 2007 | 06:26 AM
projectSHO89's Avatar
projectSHO89
..and go out and unplug the speed control disconnect switch (just in case) to keep you about-to-be acquired truck from doing a "Cheech and Chong" (Up in Smoke).
Go here: http://www.ford.com/en/vehicles/owne...ls/default.htm
Steve
Old Aug 19, 2007 | 06:36 AM
ncranchero's Avatar
ncranchero
Steve
You're tellin' your age with that one!
From what I've read, he's in FL and the truck is in NY..... but yeah, get your dad to unplug it!
Old Aug 19, 2007 | 06:53 AM
projectSHO89
No kidding. I got my first piece of junk mail from AARP this month....
Steve
Old Aug 19, 2007 | 06:59 AM
ncranchero's Avatar
ncranchero
[QUOTE=projectSHO89]
QUOTE]
Steve
Well I'm about 2 years ahead of you on that one! Hey, I'm thrilled I've made it long enough to get AARP junk mail!
Old Aug 19, 2007 | 08:39 PM
Club Wagon's Avatar
Club Wagon
Thanks for the information. Unfortunately I found the 'page unavailable' when i entered the VIN. Off hand do you know which cruise control switch is the culprit? Is it the one on the brake pedal?
Yes, the F-150 is located at distance in my Dad's garage.
Don't joke about AARP until after you've asked them to quote you on auto insurance & compared to who you have now.
As my friends reach 50 I tell them that now they don't just have one foot in the grave, they've got 50% of their weight on that foot. Don't know anyobdy who's getting any younger.
Old Aug 20, 2007 | 01:50 PM
galaxie641's Avatar
galaxie641
It is actually a plug on the front of the brake master cylinder, chances are VERY slim it will ever be a problem but if you want you can unplug it. Recalls pertain to the vehicle no matter the owner, some have mileage and/or time requirements although I know of none with the cruise recall. You can simply take the VIN and/or the truck to any Ford dealer and they can run an OASIS report and will know what has and has not been done to it.
Old Aug 21, 2007 | 01:25 AM
Club Wagon's Avatar
Club Wagon
Thanks, will try the "OASIS report" this week & the online link again later tonight.
Talked w/my Dad again tonight & he couldn't remember anything on recalls, but told me he bought it at a dealer further away, took it the closest dealer, then got miffed & went to a 3rd dealer an intermediate distance away for what little service it received in 10 years & 7500 miles. The good news is he's probably kept ever bit of paperwork he ever had on the F-150. Just a matter of finding it.
Old Aug 21, 2007 | 07:41 PM
alberta46's Avatar
alberta46
go to the top of this page and hit recalls tsbs section might help you out
edzeb
Apr 10, 2013 07:43 AM
BigSix1
15
Aug 8, 2006 09:31 AM
wresleu
1997 - 2003 F150
Nov 22, 2005 03:16 PM
bunky
24
Oct 29, 2005 06:49 PM
jtesb
1997 - 2003 F150
Apr 5, 2004 08:34 AM
